@Anonymous wrote:
1. .... is it possible to use a spline type leader with multiple points ....
2. can we round up the measurement up to the next foot if there are inches (ex 1'-1 1/2" = 2' or 5'-7" = 6'). ....
The attached is close. The one drawback is that after the second point designation in the Leader, you don't see it forming as you pick points, until you end it, then it's drawn in and the text goes in. I'm not sure whether there's a way to get around that, but if I think of anything, I'll be back. I suggest [if you don't already as I do] turning on .BLIPMODE so you can see what points you've picked so far, and you can route it around stuff with a good idea of where it's going. That could be built in, if you like, and turned off at the end if you don't normally use Blips. [I always have them on -- I find they provide very useful information -- but a lot of people hate them, or don't even know about them.]
[EDIT: The description in the second line should also include that it's the rounded-up-to-the-next-foot version.]
Kent Cooper, AIA
