polyline length on leader
Message 1 of 39
is there a lisp or program where i can click on a polyline and show the length of that line on the end of a leader that i can move around and drop off
Accepted solutions (4)
Replies (38)
Message 21 of 39
here is a screen shot.
i apploaded the file. typed test. and then i get this
Message 22 of 39
Kent1Cooper
@Anonymous wrote:
on mine when i select a line it only lets me choose the one line. and then it ask me to choose a point perpendicular to the line. and the only thing that it is measuring is the length of where the leader starts away from the line
do i need to change some settings or something?
i am using the command test to start using the lisp after i appload it.
What you need to change is the command name you're using.  TEST is the command name from the other routine from @Satish_Rajdev.  The command name in mine is LTLL [always the part that immediately follows (defun C:  in the command-defining code].
Kent Cooper, AIA
Message 23 of 39
duhhh!!!!!!!!!!!!!!
omg success!!!!!!!!!! its not selecting the 90 degree bends where i camfered. but everything else is perfect!
yea using the right command to start the routine helps considerably.
Message 24 of 39
the last thing is being able to select the filleted bends and add that into the total measurement if that is possible. and if the text can come at the end of the leader instead of being positioned above the leader. if you can do that you are my hero.
thank you for all the hard work so far, you are doing a really good job and its appreciated
Message 25 of 39
Kent1Cooper
@Anonymous wrote:
the last thing is being able to select the filleted bends and add that into the total measurement if that is possible. and if the text can come at the end of the leader instead of being positioned above the leader. ....
I'm not sure what you mean about the bends.  In Message 23 you said they were c[h]amfered, but here you say filleted.  If Chamfered, are they not also Lines like the rest, that you can select along with the rest?  If filleted, Arcs would need to be added to the selection filter, and a different method would be needed to get their length [Arcs don't have a 'Length VLA Property as Lines do] -- not difficult, but I'll wait to hear whether Arcs are involved.
Where the text lies in relation to the Leader line element is a function of the DimStyle of the Leader -- modify that to place the text where you want it [or make a separate Style for these, if you don't want to affect Dimensions that use that Style].
Kent Cooper, AIA
Message 26 of 39
attached is a screenshot while in the middle of the command where you can see that straight lines are selected but the fillet (bends) can not be selected and added into the overall total length
Message 27 of 39
we typically use a 6" radius with the fillet command to make our bends
Message 28 of 39
Kent1Cooper
So, Filleted rather than Chamfered.  Try the attached [note that I added a letter to both the file name and the command name ].
BUT if these are always contiguous-at-their-ends series of Lines and Arcs [or all Lines if Chamfered], I would strongly recommend that you make them as Polylines  instead of all those separate pieces!  It would use less memory.  You can do line segments for the "base" route [or, if you have Lines already, join them together into a Polyline with either JOIN or PEDIT's Join option], and then you can Fillet or Chamfer all the bends at once, using the Polyline option in either command.  Not to mention that it would involve selection of only one  object in a routine to do this labeling, and the determination of its length would be direct and immediate, not by a calculation involving stepping through separate objects and adding up their lengths.
Kent Cooper, AIA
Message 29 of 39
how do i get the text to dome at the end of the leader line instead of on top of it?
Message 30 of 39
to come at the end of the line.... not dome
i want the text centered with a small gap at the end of the leader line. currently it comes above the leader line.
ps.
thanks for the heads up on the poly line to use less memory
Message 31 of 39
text location
Message 32 of 39
Kent1Cooper
@Anonymous wrote:
how do i get the text to dome at the end of the leader line instead of on top of it? ....
DIMSTYLE command [just plain D is the default alias for it]; pick the applicable Style name; Modify...; Text tab; Text placement area.
Kent Cooper, AIA
Message 33 of 39
ok man thats perfect. its exactly what i wanted and exactly what i needed. you did a great job. thank you for your time. i am 100% happy and satisfied.
not just good job, GREAT JOB!!!
THANK YOU THANK YOU THANK YOU!!!!
Message 34 of 39
2 things I was wondering if we could tweak this lisp slightly.
1. we are really cramped for space, is it possible to use a spline type leader with multiple points so that we can navigate around items on our sheet before we drop off the text. something like after we choose the conduit to measure and hit enter, then we left click on the line to start the leader & we draw the spline with multiple points then hit enter to drop off the text.
2. can we round up the measurement up to the next foot if there are inches (ex 1'-1 1/2" = 2' or 5'-7" = 6'). As stated before we are really cramped for space and getting rid of the inches would save a lot of space on the drawings in cramped areas.
Message 35 of 39
Kent1Cooper
@Anonymous wrote:
1. .... is it possible to use a spline type leader with multiple points ....
2. can we round up the measurement up to the next foot if there are inches (ex 1'-1 1/2" = 2' or 5'-7" = 6'). ....
The attached is close.  The one drawback is that after the second point designation in the Leader, you don't see it forming  as you pick points, until you end it, then it's drawn in and the text goes in.  I'm not sure whether there's a way to get around that, but if I think of anything, I'll be back.  I suggest [if you don't already as I do] turning on .BLIPMODE so you can see what points you've picked so far, and you can route it around stuff with a good idea of where it's going.  That could be built in, if you like, and turned off at the end if you don't normally use Blips.  [I always have them on -- I find they provide very useful information -- but a lot of people hate them, or don't even know about them.]
[EDIT:  The description in the second line should also include that it's the rounded-up-to-the-next-foot version.]
Kent Cooper, AIA
Message 36 of 39
john.uhden
One thing to consider is using a narrower text style. In my previous job I
was a little shocked to see that the company standard was a width factor of
0.65. It saved a lot of room and was surprisingly easy to read. I am now
using a width factor of 0.75 with no complaints at all.
John F. Uhden
Message 37 of 39
john.uhden
You love using (command ...).
Why not just set the mtext option to none, invoke the leader command, and when it's done pick up the last coordinate and add the mtext.  Now it won't be attached, but that's easy to fix.
John F. Uhden
Message 38 of 39
thanks kent, this works like a champ
Message 39 of 39
Kent1Cooper
It seems you can set a no-annotation option in a way that "sticks" for MultiLeaders  and for Qleaders, but apparently not for "basic" Leaders [at least I haven't found the way] -- it has to be called for within the command every time as an option after getting to the end of the leader part, so that doesn't help.  But if the routine switched over to using a MultiLeader to get that possibility, then by completing it with no annotation and putting that in separately, you wouldn't get the turning of the tail end of the leader part to "aim" at the text, and you would need to save defining points to do calculations based on [presumably] the last two of them to decide which way to go from the last one for the text insertion point and what its justification should be.  BUT if those are worth working into it, given the task at hand, in one way I like the idea of independent Text, as a "plain" Text object, because Mtext is really overkill for just an integer with a foot-mark after it.
Kent Cooper, AIA
