Visual LISP, AutoLISP and General Customization
Please help me write LISP
14 REPLIES 14
Message 1 of 15
chan230984
1234 Views, 14 Replies
I want to click Point 3 Point A,B,C
and I want to show table coordinate Northing and Easting (text height = 0.16)
 Picture below
thanks
14 REPLIES 14
Message 2 of 15
CADaSchtroumpf
in reply to: chan230984
Try this if can be usefull
(vl-load-com)
(defun c:points2cell ( / js AcDoc Space nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n
                         obj dxf_10 nb nw_obj ename_cell n_row n_column)
  (princ "\nSelect points.")
  (while (null (setq js (ssget '((0 . "POINT")))))
    (princ "\nSelection empty, or is not a point!")
  (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space
    (if (= 1 (getvar "CVPORT"))
      (vla-get-PaperSpace AcDoc)
      (vla-get-ModelSpace AcDoc)
  (cond
    ((null (tblsearch "LAYER" "Table-Points"))
      (vla-add (vla-get-layers AcDoc) "Table-Points")
  (cond
    ((null (tblsearch "STYLE" "Text-Cell"))
      (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell"))
      (mapcar
        '(lambda (pr val)
          (vlax-put nw_style pr val)
        (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
        (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
      (command "_.ddunits"
        (while (not (zerop (getvar "cmdactive")))
          (command pause)
  (setq
    oldim (getvar "dimzin")
    oldlay (getvar "clayer")
  (setvar "dimzin" 0) (setvar "clayer" "Table-Points")
  (initget 9)
  (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: "))
  (initget 6)
  (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: ")))
  (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t))
  (initget 7)
  (setq w_c (getdist ins_pt_cell "\nWidth of cells: "))
  (setq
    lst_id-seg '()
    lst_pt '()
    nb 0
  (repeat (setq n (sslength js))
    (setq
      obj (ssname js (setq n (1- n)))
      dxf_10 (cdr (assoc 10 (entget obj)))
      lst_pt (cons dxf_10 lst_pt)
      nb (1+ nb)
      lst_id-seg (cons nb lst_id-seg)
  (mapcar
    '(lambda (p tx)
      (setq nw_obj
        (vla-addMtext Space
          (vlax-3d-point p)
          0.0
          tx
      (mapcar
        '(lambda (pr val)
          (vlax-put nw_obj pr val)
        (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
        (list 5 h_t 5 p "Text-Cell" "Table-Points" 0.0)
    lst_pt
    lst_id-seg
  (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 3 (+ h_t (* h_t 0.25)) w_c)
  (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1)
  (vla-SetCellValue ename_cell 0 0
    (vlax-make-variant
      (strcat "Summary of " (itoa (sslength js)) " POINTS")
      8
  (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell")
  (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5))
  (vla-SetCellAlignment ename_cell 0 0 5)
  (foreach n
    (mapcar'list
      (append lst_id-seg '("N°"))
      (append (mapcar 'rtos (mapcar 'car lst_pt)) '("Coordinates X"))
      (append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("Coordinates Y"))
    (mapcar
      '(lambda (el)
        (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column))
          (if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8))
        (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell")
        (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5))
        (if (eq n_row 1)
          (vla-SetCellAlignment ename_cell n_row n_column 5)
          (vla-SetCellAlignment ename_cell n_row n_column 6)
      n
    (setq n_row (1- n_row) n_column -1)
  (setvar "dimzin" oldim) (setvar "clayer" oldlay)
  (prin1)
Message 3 of 15
chan230984
in reply to: CADaSchtroumpf
@CADaSchtroumpf
Hi, It's not 1 2 3 but it's A B C
Message 4 of 15
Sea-Haven
Where the code does a inc number you do the same but must use (chr x) the x is the key value for "A" etc please note you are limited to 26 characters.
(setq x 65)
(repeat 5
(alert (strcat (rtos x 2 0) "  =  " (chr x)))
(setq x (+ x 1))
Message 5 of 15
chan230984
in reply to: Sea-Haven
@Sea-Haven
how doI have no knowledge In this program
please write
Message 6 of 15
Sea-Haven
It would be best for the other code poster to add to his/her code.
Message 7 of 15
CADaSchtroumpf
Adapted to your exemple.
(vl-load-com)
(defun inc_txt (Txt / Boucle Decalage Val_Txt)
	(setq Boucle 1 Val_txt "")
	(while (<= Boucle (strlen Txt))
		(setq Ascii_Txt (vl-string-elt Txt (- (strlen Txt) Boucle)))
		(if (not Decalage)
			(setq Ascii_Txt (1+ Ascii_Txt))
		(if (or (= Ascii_Txt 58) (= Ascii_Txt 91) (= Ascii_Txt 123))
			(setq
				Ascii_Txt
					(cond
						((= Ascii_Txt 58) 48)
						((= Ascii_Txt 91) 65)
						((= Ascii_Txt 123) 97)
				Decalage nil
			(setq Decalage T)
		(setq Val_Txt (strcat (chr Ascii_Txt) Val_Txt))
		(setq Boucle (1+ Boucle))
	(if (not Decalage)
		(setq Val_Txt (strcat (cond ((< Ascii_Txt 58) "0") ((< Ascii_Txt 91) "A") ((< Ascii_Txt 123) "a")) Val_Txt))
	Val_Txt
(defun c:points2cell ( / js AcDoc Space acmCol nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n
												 obj dxf_10 nb n_ini n_next nw_obj ename_cell n_row n_column)
	(setq
		Space
		acmCol
		(vla-getinterfaceobject
			(strcat
				"AutoCAD.AcCmColor."
				(substr (getvar "ACADVER") 1 2)
	(cond
		((null (tblsearch "LAYER" "XFG"))
			(vlax-put (vla-add (vla-get-layers AcDoc) "XFG") 'Color 1)
	(cond
		((null (tblsearch "STYLE" "TAHOMA"))
			(setq nw_style (vla-add (vla-get-textstyles AcDoc) "TAHOMA"))
			(mapcar
				'(lambda (pr val)
				(list (strcat (getenv "windir") "\\fonts\\Tahoma.ttf") 0.0 0.0 1.0 0.0)
					(command pause)
	(setq
	(setvar "dimzin" 0) (setvar "clayer" "XFG")
	(initget 9)
	(initget 6)
	(initget 7)
	(setq
		lst_id-seg '()
		lst_pt '()
		nb 0
		n_ini "@"
		n_next n_ini
		(setq
			nb (1+ nb)
			n_ini n_next
			lst_id-seg (cons (setq n_next (inc_txt n_ini)) lst_id-seg)
	(mapcar
		'(lambda (p tx)
			(setq nw_obj
				(vla-addMtext Space
					(vlax-3d-point p)
					0.0
					tx
			(mapcar
				'(lambda (pr val)
				(list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'color)
				(list 5 h_t 5 p "TAHOMA" "XFG" 0.0 4)
		lst_pt
		lst_id-seg
	(vla-setrgb acmCol 0 255 255)
		(vlax-make-variant
			"TABLE OF COORDINATES"
			8
	(vla-SetCellTextStyle ename_cell 0 0 "TAHOMA")
	(vla-SetCellContentColor ename_cell 0 0 acmCol)
	(foreach n
		(mapcar'list
			(append lst_id-seg '("MARK"))
			(append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("NORTHING"))
			(append (mapcar 'rtos (mapcar 'car lst_pt)) '("EASTING"))
		(mapcar
			'(lambda (el)
				(vla-SetCellTextStyle ename_cell n_row n_column "TAHOMA")
				(if (eq n_row 1)
					(progn
						(vla-SetCellContentColor ename_cell n_row n_column acmCol)
			n
	(prin1)
Message 8 of 15
chan230984
@CADaSchtroumpf
that's right
But I would like to disturb a little more.
I want the numbers to be in the middle Center
Please help me
Message 9 of 15
devitg
Please apologize me , I don't find any points at samples.dwg'
Would you clear me??
Thanks in advance.
Message 10 of 15
chan230984
in reply to: devitg
@devitg
Sorry, I'm not good at English.
Message 11 of 15
devitg
I mean : there is no points at your dwg . It are Lines and circles
What is your idiom??
Message 12 of 15
devitg
in reply to: devitg
NO
จุด
Cud
Message 13 of 15
chan230984
in reply to: devitg
@devitg
At that point, I will create later.
Can put a circle or not
Is that I want the coordinate , table And the symbol A B C
Message 14 of 15
CADaSchtroumpf
Find and replace
by
Message 15 of 15
devitg
Ok . Understood it.
AutoCAD Inside the Factory
