- Mute
- Permalink
- Report
I want to click Point 3 Point A,B,C
and I want to show table coordinate Northing and Easting (text height = 0.16)
Picture below
thanks
Picture below
thanks
Try this if can be usefull
(vl-load-com) (defun c:points2cell ( / js AcDoc Space nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n obj dxf_10 nb nw_obj ename_cell n_row n_column) (princ "\nSelect points.") (while (null (setq js (ssget '((0 . "POINT"))))) (princ "\nSelection empty, or is not a point!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (cond ((null (tblsearch "LAYER" "Table-Points")) (vla-add (vla-get-layers AcDoc) "Table-Points") ) ) (cond ((null (tblsearch "STYLE" "Text-Cell")) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0) ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) ) ) (setq oldim (getvar "dimzin") oldlay (getvar "clayer") ) (setvar "dimzin" 0) (setvar "clayer" "Table-Points") (initget 9) (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: ")) (initget 6) (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: "))) (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t)) (initget 7) (setq w_c (getdist ins_pt_cell "\nWidth of cells: ")) (setq lst_id-seg '() lst_pt '() nb 0 ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) dxf_10 (cdr (assoc 10 (entget obj))) lst_pt (cons dxf_10 lst_pt) nb (1+ nb) lst_id-seg (cons nb lst_id-seg) ) ) (mapcar '(lambda (p tx) (setq nw_obj (vla-addMtext Space (vlax-3d-point p) 0.0 tx ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation) (list 5 h_t 5 p "Text-Cell" "Table-Points" 0.0) ) ) lst_pt lst_id-seg ) (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 3 (+ h_t (* h_t 0.25)) w_c) (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1) (vla-SetCellValue ename_cell 0 0 (vlax-make-variant (strcat "Summary of " (itoa (sslength js)) " POINTS") 8 ) ) (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell") (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5)) (vla-SetCellAlignment ename_cell 0 0 5) (foreach n (mapcar'list (append lst_id-seg '("N°")) (append (mapcar 'rtos (mapcar 'car lst_pt)) '("Coordinates X")) (append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("Coordinates Y")) ) (mapcar '(lambda (el) (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8)) ) (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell") (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5)) (if (eq n_row 1) (vla-SetCellAlignment ename_cell n_row n_column 5) (vla-SetCellAlignment ename_cell n_row n_column 6) ) ) n ) (setq n_row (1- n_row) n_column -1) ) (setvar "dimzin" oldim) (setvar "clayer" oldlay) (prin1) )
Where the code does a inc number you do the same but must use (chr x) the x is the key value for "A" etc please note you are limited to 26 characters.
(setq x 65) (repeat 5 (alert (strcat (rtos x 2 0) " = " (chr x))) (setq x (+ x 1)) )
It would be best for the other code poster to add to his/her code.
Adapted to your exemple.
(vl-load-com) (defun inc_txt (Txt / Boucle Decalage Val_Txt) (setq Boucle 1 Val_txt "") (while (<= Boucle (strlen Txt)) (setq Ascii_Txt (vl-string-elt Txt (- (strlen Txt) Boucle))) (if (not Decalage) (setq Ascii_Txt (1+ Ascii_Txt)) ) (if (or (= Ascii_Txt 58) (= Ascii_Txt 91) (= Ascii_Txt 123)) (setq Ascii_Txt (cond ((= Ascii_Txt 58) 48) ((= Ascii_Txt 91) 65) ((= Ascii_Txt 123) 97) ) Decalage nil ) (setq Decalage T) ) (setq Val_Txt (strcat (chr Ascii_Txt) Val_Txt)) (setq Boucle (1+ Boucle)) ) (if (not Decalage) (setq Val_Txt (strcat (cond ((< Ascii_Txt 58) "0") ((< Ascii_Txt 91) "A") ((< Ascii_Txt 123) "a")) Val_Txt)) ) Val_Txt ) (defun c:points2cell ( / js AcDoc Space acmCol nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n obj dxf_10 nb n_ini n_next nw_obj ename_cell n_row n_column) (princ "\nSelect points.") (while (null (setq js (ssget '((0 . "POINT"))))) (princ "\nSelection empty, or is not a point!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) acmCol (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2) ) ) ) (cond ((null (tblsearch "LAYER" "XFG")) (vlax-put (vla-add (vla-get-layers AcDoc) "XFG") 'Color 1) ) ) (cond ((null (tblsearch "STYLE" "TAHOMA")) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "TAHOMA")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list (strcat (getenv "windir") "\\fonts\\Tahoma.ttf") 0.0 0.0 1.0 0.0) ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) ) ) (setq oldim (getvar "dimzin") oldlay (getvar "clayer") ) (setvar "dimzin" 0) (setvar "clayer" "XFG") (initget 9) (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: ")) (initget 6) (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: "))) (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t)) (initget 7) (setq w_c (getdist ins_pt_cell "\nWidth of cells: ")) (setq lst_id-seg '() lst_pt '() nb 0 n_ini "@" n_next n_ini ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) dxf_10 (cdr (assoc 10 (entget obj))) lst_pt (cons dxf_10 lst_pt) nb (1+ nb) n_ini n_next lst_id-seg (cons (setq n_next (inc_txt n_ini)) lst_id-seg) ) ) (mapcar '(lambda (p tx) (setq nw_obj (vla-addMtext Space (vlax-3d-point p) 0.0 tx ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation 'color) (list 5 h_t 5 p "TAHOMA" "XFG" 0.0 4) ) ) lst_pt lst_id-seg ) (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 3 (+ h_t (* h_t 0.25)) w_c) (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1) (vla-setrgb acmCol 0 255 255) (vla-SetCellValue ename_cell 0 0 (vlax-make-variant "TABLE OF COORDINATES" 8 ) ) (vla-SetCellTextStyle ename_cell 0 0 "TAHOMA") (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5)) (vla-SetCellAlignment ename_cell 0 0 5) (vla-SetCellContentColor ename_cell 0 0 acmCol) (foreach n (mapcar'list (append lst_id-seg '("MARK")) (append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("NORTHING")) (append (mapcar 'rtos (mapcar 'car lst_pt)) '("EASTING")) ) (mapcar '(lambda (el) (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8)) ) (vla-SetCellTextStyle ename_cell n_row n_column "TAHOMA") (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5)) (if (eq n_row 1) (vla-SetCellAlignment ename_cell n_row n_column 5) (progn (vla-SetCellAlignment ename_cell n_row n_column 6) (vla-SetCellContentColor ename_cell n_row n_column acmCol) ) ) ) n ) (setq n_row (1- n_row) n_column -1) ) (setvar "dimzin" oldim) (setvar "clayer" oldlay) (prin1) )
that's right
But I would like to disturb a little more.
I want the numbers to be in the middle Center
Please help me
Please apologize me , I don't find any points at samples.dwg'
Would you clear me??
Thanks in advance.
I mean : there is no points at your dwg . It are Lines and circles
What is your idiom??
At that point, I will create later.
Can put a circle or not
Is that I want the coordinate , table And the symbol A B C
Find and replace
by
Ok . Understood it.
