Try this if can be usefull
(vl-load-com)
(defun c:points2cell ( / js AcDoc Space nw_style oldim oldlay ins_pt_cell h_t w_c lst_id-seg lst_pt n
obj dxf_10 nb nw_obj ename_cell n_row n_column)
(princ "\nSelect points.")
(while (null (setq js (ssget '((0 . "POINT")))))
(princ "\nSelection empty, or is not a point!")
(setq
AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
Space
(if (= 1 (getvar "CVPORT"))
(vla-get-PaperSpace AcDoc)
(vla-get-ModelSpace AcDoc)
(cond
((null (tblsearch "LAYER" "Table-Points"))
(vla-add (vla-get-layers AcDoc) "Table-Points")
(cond
((null (tblsearch "STYLE" "Text-Cell"))
(setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell"))
(mapcar
'(lambda (pr val)
(vlax-put nw_style pr val)
(list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
(list (strcat (getenv "windir") "\\fonts\\arial.ttf") 0.0 (/ (* 15.0 pi) 180) 1.0 0.0)
(command "_.ddunits"
(while (not (zerop (getvar "cmdactive")))
(command pause)
(setq
oldim (getvar "dimzin")
oldlay (getvar "clayer")
(setvar "dimzin" 0) (setvar "clayer" "Table-Points")
(initget 9)
(setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: "))
(initget 6)
(setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: ")))
(if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t))
(initget 7)
(setq w_c (getdist ins_pt_cell "\nWidth of cells: "))
(setq
lst_id-seg '()
lst_pt '()
nb 0
(repeat (setq n (sslength js))
(setq
obj (ssname js (setq n (1- n)))
dxf_10 (cdr (assoc 10 (entget obj)))
lst_pt (cons dxf_10 lst_pt)
nb (1+ nb)
lst_id-seg (cons nb lst_id-seg)
(mapcar
'(lambda (p tx)
(setq nw_obj
(vla-addMtext Space
(vlax-3d-point p)
0.0
tx
(mapcar
'(lambda (pr val)
(vlax-put nw_obj pr val)
(list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
(list 5 h_t 5 p "Text-Cell" "Table-Points" 0.0)
lst_pt
lst_id-seg
(vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 3 (+ h_t (* h_t 0.25)) w_c)
(setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1)
(vla-SetCellValue ename_cell 0 0
(vlax-make-variant
(strcat "Summary of " (itoa (sslength js)) " POINTS")
8
(vla-SetCellTextStyle ename_cell 0 0 "Text-Cell")
(vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5))
(vla-SetCellAlignment ename_cell 0 0 5)
(foreach n
(mapcar'list
(append lst_id-seg '("N°"))
(append (mapcar 'rtos (mapcar 'car lst_pt)) '("Coordinates X"))
(append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("Coordinates Y"))
(mapcar
'(lambda (el)
(vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column))
(if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8))
(vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell")
(vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5))
(if (eq n_row 1)
(vla-SetCellAlignment ename_cell n_row n_column 5)
(vla-SetCellAlignment ename_cell n_row n_column 6)
n
(setq n_row (1- n_row) n_column -1)
(setvar "dimzin" oldim) (setvar "clayer" oldlay)
(prin1)
