06:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone, now i have a lisp can be calculating and insert text grade value for polyline. But it can select a single polyline. Now i want to select mutiple polyline (or mutiple line if possible), so somebody can help me to edit this lisp
(defun c:gd (/ entpl p1 text_height sp ep ang grade) (vl-load-com) (setq entpl (entsel "\n Select Polyline") entob (vlax-ename->vla-object (car entpl)) ) (setq x (getreal "\n Scale X: ") y (getreal "\n Scale Y: ")) (setq text_height (getreal "\n Text Height: ") h (getreal "\n Distanse from Text to Polyline: ") i 0 p1 (cadr entpl) ent (car entpl) m (vlax-curve-getendparam ent)) (while (< i m) (setq sp (vlax-curve-getPointatparam ent i) ep (vlax-curve-getPointatparam ent (1+ i)) ang (angle sp ep) x1 (car sp) y1 (cadr sp) x2 (car ep) y2 (cadr ep) grade (* (abs (/ (/ (- y2 y1) y) (/ (- x2 x1) x))) ) grade (strcat (rtos grade) )) (if (< (car sp) (car ep)) (progn (setq pt (vlax-curve-getpointatparam ent (+ i 0.1))) (command "_.text" (list (- (car pt) (* h (sin ang))) (+ (cadr pt) (* h (cos ang)))) text_height (/ (* ang 180) pi)(strcat grade)) ) (if (> (car sp) (car ep)) (progn (setq pt (vlax-curve-getpointatparam ent (+ i 0.9))) (command "_.text" (list (+ (car pt) (* h (sin ang))) (+ (cadr pt) (* h (cos ang)))) text_height (+ 180 (/ (* ang 180) pi)) (strcat grade)) ) (progn (setq pt (vlax-curve-getpointatparam ent (+ i 0.5))) (command "_.text" (list (+ (car pt) h) (cadr pt)) text_height 90 (strcat grade)) ) ) ) (setq i (1+ i)) ) )
Thank everyone for reading and please help me!
