(princ "\nPoint #2") I don't understand why it is printed twice.
Hi, guys!
Please help me to understand the logic of (princ)
This is the program I have
(defun c:PrintTest()
;(setq p2 3)
; (princ)
(princ "\nPoint #2") ;(princ p2)
;(princ (strcat "\nPoint #2 " (rtos (car p2) 2) "," (rtos (cadr p2) 2) "," (rtos (last p2) 2)))
I pasted it "as is" without removing comments.
When I run program, I get the following result:
Command: PRINTTEST
Point #2"\nPoint #2
Thanks!
ВeekeeCZ
Since you have replied here I guess you do understand now.
In case you're not see the help.
Especially this part: ...
Return Values
Type: Integer, Real, String, List, Symbol, File, Ename (entity name), T, or nil
The value of the evaluated expr. If called with no arguments, princ returns a null symbol.
The red part is why it is twice. The blue one why we put (princ) at the and to avoid previous.
Thanks for reply!
Now, I know how to fix this situation,
but I don't understand why it works
The first (princ "\nPoint #2") returns vallue,
the second (princ) returns null
So, I don't understand why second null prevent returning value of the the first princ?
Thanks!
ВeekeeCZ
@Anonymous wrote:
Thanks for reply!
Thanks!
It's not. In command line you can see just last one.
Try to write into command line this:
(setq a 1)
then !a to get value of a
Then (setq b 1)(princ)
try !b
So see help what setq returns. If you put (princ) right behind... you'll see nothing. But it's still there. You can catch it with
(setq d (setq c 2))(princ)
then if you type !d it returns same value as !c which is 2.
Yes, this explain the issue!
thanks!
