;;; ! lib:IsPtInView *
;; ECO """"
(defun lib:IsPtInView (pt / VCTR Y_Len SSZ X_Pix Y_Pix X_Len Lc Uc)
(setq pt (trans pt 0 1))
(setq VCTR (getvar "VIEWCTR")
Y_Len (getvar "VIEWSIZE")
SSZ (getvar "SCREENSIZE")
X_Pix (car SSZ)
Y_Pix (cadr SSZ)
X_Len (* (/ X_Pix Y_Pix) Y_Len)
Lc (polar VCTR (dtr 180.0) (* 0.5 X_Len))
Uc (polar Lc 0.0 X_Len)
Lc (polar Lc (dtr 270.0) (* 0.5 Y_Len))
Uc (polar Uc (dtr 90.0) (* 0.5 Y_Len))
(if (and (> (car pt) (car Lc))
(< (car pt) (car Uc))
(> (cadr pt) (cadr Lc))
(< (cadr pt) (cadr Uc))
T
nil
(defun DTR (a) (* pi (/ a 180.0)))
(defun RTD (a) (/ (* a 180.0) pi))
;; ! lib:Zoom2Lst *
(defun lib:Zoom2Lst (vlist / bl tr Lst OS)
(setq Lst (lib:pt_extents vlist)
bl (car Lst)
tr (cadr Lst)
(if (not (and (lib:IsPtInView bl) (lib:IsPtInView tr)))
(progn (setq OS (getvar "OSMODE"))
(setvar "OSMODE" 0)
(command "_.Zoom"
"_Window"
(trans bl 0 1)
(trans tr 0 1)
"_.Zoom"
"0.95x"
(setvar "OSMODE" OS)
T
NIL
;; ! lib:pt_extents *
(defun lib:pt_extents (vlist / tmp)
(setq tmp
(mapcar
'(lambda (x) (vl-remove-if 'null x))
(mapcar
'(lambda (what)
(mapcar '(lambda (x)
(nth what x)
vlist
'(0 1 2)
) ;_setq
(list
(mapcar
'(lambda (x)
(apply 'min x)
tmp
(mapcar '(lambda (x) (apply 'max x)) tmp)
) ;_defun
http://www.autocad.ru/cgi-bin/f1/board.cgi?t=30724Ed;External contour of objects
(defun C:ECO (/ *error* blk obj MinPt MaxPt hiden
pt pl unnamed_block isRus tmp_blk adoc
blks lays lay oname sel csp loc
sc ec ret DS osm
(defun *error* (msg)
(vla-put-Visible x :vlax-true)
hiden
(vla-endundomark adoc)
(if (and tmp_blk
(not
(vlax-erased-p tmp_blk)
(vlax-write-enabled-p tmp_blk)
(vla-Erase tmp_blk)
(if osm
(setvar "OSMODE" osm)
(foreach x loc (vla-put-lock x :vlax-true))
(vl-load-com)
(setvar "CMDECHO" 0)
(setq osm (getvar "OSMODE"))
(if
(zerop (getvar "WORLDUCS"))
(progn
(vl-cmdf "_.UCS" "")
(vl-cmdf "_.Plan" "")
(setq isRus
(= (getvar "SysCodePage") "ANSI_1251")
(setq adoc
(vla-get-ActiveDocument
(vlax-get-acad-object)
blks (vla-get-blocks adoc)
lays
(vla-get-layers adoc)
(vla-startundomark adoc)
(if isRus
(princ "\nВыберите объекты для построения контура")
(princ "\nSelect objects for making a contour")
(if (setq sel (ssget))
(progn
(setq sel
(mapcar 'vlax-ename->vla-object
(vl-remove-if
'listp
(mapcar 'cadr (ssnamex sel))
(setq csp
(vla-objectidtoobject
adoc
(vla-get-ownerid (car sel))
(setq unnamed_block
(vla-add (vla-get-blocks adoc)
(vlax-3d-point '(0. 0. 0.))
"*U"
(foreach x sel
(setq oname
(strcase (vla-get-objectname x))
lay
(vla-item lays (vla-get-layer x))
(if (= (vla-get-lock lay) :vlax-true)
(progn
(vla-put-lock lay :vlax-false)
(setq loc (cons lay loc))
(cond
((member oname '("ACDBVIEWPORT" "ACDBATTRIBUTEDEFINITION"))
nil
((= oname "ACDBBLOCKREFERENCE")
(vla-InsertBlock
unnamed_block
(vla-get-insertionpoint x)
(vla-get-name x)
(vla-get-xscalefactor x)
(vla-get-yscalefactor x)
(vla-get-zscalefactor x)
(vla-get-rotation x)
(setq blk (cons x blk))
(t (setq obj (cons x obj)))
) ;_foreach
(setq lay
(vla-item lays (getvar "CLAYER"))
(if
(progn (vla-put-lock lay :vlax-false)
(if obj
(progn
(vla-copyobjects
(vla-get-activedocument
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray
vlax-vbobject
(cons 0 (1- (length obj)))
obj
unnamed_block
(setq obj (append obj blk))
(if obj
(progn
(setq tmp_blk (vla-insertblock
csp
(vla-get-name unnamed_block)
1.0
1.0
1.0
0.0
(vla-GetBoundingBox tmp_blk 'MinPt 'MaxPt) ;_Границы блока
(setq MinPt (vlax-safearray->list MinPt)
MaxPt (vlax-safearray->list MaxPt)
DS (max (distance MinPt (list (car MinPt) (cadr MaxPt)))
(distance MinPt (list (car MaxPt) (cadr MinPt)))
DS (* 0.2 DS) ;1/5
DS (max DS 10)
MinPt (mapcar '- MinPt (list DS DS))
MaxPt (mapcar '+ MaxPt (list DS DS))
(lib:Zoom2Lst (list MinPt MaxPt))
(setq sset (ssget "_C" MinPt MaxPt))
(if sset
(progn
(setvar "OSMODE" 0)
(setq hiden (mapcar 'vlax-ename->vla-object
(vl-remove-if
'listp
(mapcar 'cadr (ssnamex sset))
hiden (vl-remove tmp_blk hiden)
(mapcar '(lambda (x) (vla-put-Visible x :vlax-false))
hiden
(setq pt (mapcar '+ MinPt (list (* 0.5 DS) (* 0.5 DS))))
(vl-cmdf "_.RECTANG" (trans MinPt 0 1) (trans MaxPt 0 1))
(setq pl (vlax-ename->vla-object (entlast)))
(setq sc (1- (vla-get-count csp)))
(if
(VL-CATCH-ALL-ERROR-P
(VL-CATCH-ALL-APPLY
'(lambda ()
(vl-cmdf "_-BOUNDARY" (trans pt 0 1) "")
(while (> (getvar "CMDACTIVE") 0) (command ""))
(if isRus
(princ "\nНе удалось построить контур")
(princ "\nIt was not possible to construct a contour")
(setq ec (vla-get-count csp))
(while (< sc ec)
(setq ret (append ret (list (vla-item csp sc)))
sc (1+ sc)
(setq ret (vl-remove pl ret))
(mapcar '(lambda (x) (vla-Erase x) (vlax-release-object x))
(list pl tmp_blk)
(setq pl nil
tmp_blk nil
(setq
ret (mapcar '(lambda (x / mipt)
(vla-GetBoundingBox x 'MiPt nil) ;_Границы блока
(setq MiPt (vlax-safearray->list MiPt))
(list MiPt x)
ret
(setq ret (vl-sort ret
'(lambda (e1 e2)
(< (distance MinPt (car e1))
(distance MinPt (car e2))
(setq pl (nth 1 ret)
(mapcar 'vla-erase (mapcar 'cadr ret))
(mapcar '(lambda (x) (vla-put-Visible x :vlax-true))
hiden
(if pl
(if isRus
(VL-CATCH-ALL-APPLY
'(lambda ()
(mapcar 'vlax-release-object
(list unnamed_block tmp_blk csp blks lays)
) ;_if not
(vlax-release-object adoc)
(princ)
(if (= (getvar "SysCodePage") "ANSI_1251")
(princ "\nНаберите в командной строке ECO")
(princ "\nType ECO in command line")
