Pick two Points to get Downslope in percents, prompted in CommandLine
Message 1 of 26
I wrote a lisp which calculates the downslope in percents and returns this downslope's value to CommandLine.
Here it is:
; DSE = DownSlopE
; DOWNSLOPE
(defun c:DOWNSLOPE
 (/ ptL1 ptL2 Len_X Len_Y Len Ang DownslopePercents)
 (setvar "cmdecho" 0)
 (setq ptL1 (getpoint "\nSpecify First Point to calculate Downslope: "))
 (setq ptL2 (getpoint "\nSpecify Second Point to calculate Downslope: "))
 (setq XptL1 (car ptL1))
 (setq YptL1 (cadr ptL1))
 (setq XptL2 (car ptL2))
 (setq YptL2 (cadr ptL2))
 (setq Len_X (- XptL2 XptL1))
 (setq Len_Y (- YptL2 YptL1))
; What if XptL1 = XptL2 --> Len_X=0?
; (setq Len
;  (sqrt
;   (+ (* Len_X Len_X) (* Len_Y Len_Y))
;  ); sqrt
; ); Len
; (setq Ang (atan Len_Y Len_X))
;Len_Y/Len_X = DownslopePercents/100
 (setq DownslopePercents (* (/ Len_Y Len_X) 100))
 (setq DownslopePercents2string (rtos DownslopePercents 2 3)); Mode=2=Engineering, Precision=3
 (princ "\nDownslope = ")
 (princ "%.")
; (princ "\nAngle = ")
; Length
; (princ " <Here should be current angle units. Should I type 'getvar AUNITS?'>.")
; (princ "\nLength = ")
; Length
; (princ ".")
);defun
Some parts of this lisp I ignore with ';', because they will be investigated in other cases - on ground of this lisp I want to write lisps which return to CommandLine Distance and Angle between two picked Points. And I can't do them using 'getdist' and 'getangle', because the user would type his own value for Distance and Angle.
So returning to the main topic: This lisp doesn't work properly.
In the CommandLine it returns:
Command: DOWNSLOPE
Downslope = %."%."
Could you please tell me why it doesn't work in way which I suspected?
Replies (25)
Message 2 of 26
Use ' strcat ' to concatenate strings.
 (princ (strcat "\nDownslope = " DownslopePercents2string "%.")) (princ)
gsktry
Message 3 of 26
hmsilva
Hi Damian,
your code, revised
; DSE = DownSlopE
; DOWNSLOPE
(defun c:DOWNSLOPE (/ angstring angun auni Ang DownslopePercents DownslopePercents2string Len Len_X Len_Y ptL1 ptL2 XptL1 XptL2 YptL1 YptL2)
  (if (and (setq ptL1 (getpoint "\nSpecify First Point to calculate Downslope: "))
	   (not (equal ptL1 ptL2 1e-8))
    (progn
      ;; (setq len (distance ptL1 ptL2))
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
      (setq angun (getvar 'aunits))
      (cond ((or (= angun 0)
		 (= angun 1)
	     (setq auni "Degrees")
	    ((= angun 2)
	     (setq auni "Gradians")
	    ((= angun 3)
	     (setq auni "Radians")
	    ((= angun 4)
	     (setq auni "Surveyor")
      (setq angstring (strcat
	     (if (minusp ang) "-" "")
	     (angtos (abs ang) angun 3)))
      ; Mode=2= Decimal, Precision=3
      (princ (strcat "\nAngle = " angstring " " auni "."))
      (princ (strcat "\nLength = " (rtos Len 2 3) "."))
    (prompt "\nYou did select the same point!!!")
  (princ)
);defun
Henrique
Message 4 of 26
Thank you, Henrique!
I added lines to get informations about Length_X, Length_Y, which are - apart from Length, Angle and Downslope in Percents, which we soon had in DOWNSLOPE lisp - the basic things we would specify in MEGALINE lsp:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/to-write-megaline-lsp/td-p/5481385
http://forums.autodesk.com/autodesk/attachments/autodesk/130/329309/1/lisp%20MEGALINE%20(3).pdf
And because not all of thesr results are visible in CommandLine (in which basically shows only two last prompts are visible), on the end. I added a prompt  to  read in CommandLine "Press [F2] button...".
Here it is:
;DRNGLXYA2POIINFHMS=
;Downslope in peRcents
;aNGle
;Length in X, Y, Aligned
;by TWO POInts
;INFo by HMSilva
(defun c:DRNGLXYA2POIINFHMS
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
	  (princ (strcat "\nLength_X = " (rtos Len_X 2 3) "."))
	  (princ (strcat "\nLength_Y = " (rtos Len_Y 2 3) "."))
	  (princ "\nPress [F2] to open and close results in CommandLine.")
;  (princ "\nPress [F2] button to open and close results in CommandLine.")
);defun
But what we will get in CommandLine is:
Command: DRNGLXYA2POIINFHMS
Downslope = 2.000%.
Length_X = 1500.000.
Length_Y = 30.000.
Angle = 1.146 Degrees.
Length = 1500.300.
Press [F2] to open and close results in CommandLine."\nPress [F2] to open and
Command:
So the error is that this program runs the final prompt twice instead of just once.
If it would run it once, the user would watch all the final prompt. But programm runs it twice and the user watches only end part of final prompt.
So I have request: COuld you tell me please, why is error here and how to write this lisp in right way?
P.S.
And I don't know why on the very end in COmmandLine the prompt "Command: " appeared.
Could you also tell me why it prompts and how to get only  "Press [F2] to open and close results in CommandLine." prompt at the end of the CommandLine?
Message 5 of 26
hmsilva
You're welcome, Damian.
The AutoCAD Command prompt, display the return from the last evaluated function, to suppress the echo, we add a princ function, without an expression, to exiting quietly.
Your code, revised
;aNGle
;by TWO POInts
;INFo by HMSilva
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
(princ);; exits quietly
);defun
And you may try to use the alert function instead of presenting the result at the command line
;aNGle
;by TWO POInts
;INFo by HMSilva
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
      (alert (strcat "\nDownslope = " DownslopePercents2string  "%."
);defun
Henrique
Message 6 of 26
Thank you, Henrique.
I hear for the first time in my life about something like the 'alert' function.
It is great that you can display the prompts in Windows TM's Window (what is its real name?).
I prefer standard CommandLine, because from the Windows TM's Window I haven't the possibility to select and copy text which is displayed in it.
And when the prompt is displayed in CommandLine, I have he possibility to select and copy text which is displayed in it.
Message 7 of 26
hmsilva
Just wanted to share another approach, using dialog box/alert box.
Henrique
Message 8 of 26
This lisp has one problem...
If we pick two points which create a vertical line (so Len_X=0 and when this lisp calculates Ang = Len_Y/Len_X, it divides by zero), the 'dividing by zero' error appears in the CommandLine.
I tried to solve this problem in two ways, but both of them generate errors, too:
; 2 -INFO ABOUT LINE BETWEEN TWO points
(defun c:2
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
    ;  (setq Ang (atan Len_Y Len_X)) ; if you pick two Points which create Vertical line, the Length_X =0 and in the CommandLine there is ""error: Divide by zero"
	 ; first way to solve this problem
	 ; that expression doesn't generate error of 'dividing by zero', but generates error of 'bad argument type: stringp'
     ;(setq Ang (getangle ptL1 ptL2))
	; second way to solve this problem.
    ; But it also generates 'dividing by zero' error.
	   if Len_X<>0
	    (if
		 YptL2>YptL1
	     (setq Ang 90)
		 (setq Ang 270)
);defun
What is the way to solve this problem?
Maybe use getangle to pick these two points (ptL1, ptL2)? But it would be a little bit not this what I want, because getangle gives possibility to TYPE OR PICK the Angle's value. And I want to have only one possibility - to PICK.
Please, help
Message 9 of 26
hmsilva
Maybe something like this will to do the trick
(Untested, I dont have AutoCAD in this laptop...)
(defun c:2
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
	(if (zerop Len_X)
	    (if (> YptL2 YptL1)
	     (setq Ang 90)
		 (setq Ang 270)
      (if (zerop Len_X)
        (setq DownslopePercents 100)
);defun
Henrique
Message 10 of 26
(if (zerop Len_X)
 (if (> YptL2 YptL1)
    (setq Ang 90)
    (setq Ang 270)
I think this red part stays in wrong place. Now this expression means: "If Len_X =0, calculate Ang=atan( Len_Y/ Len_X). And we know that if Len_X=0, the Ang is equal to 90 or 270.
So I change its position:
(if (zerop Len_X)
 (if (> YptL2 YptL1)
   (setq Ang 90)
   (setq Ang 270)
But it still returns 'divide by zero' error.
So I thought this might work:
(if (/= Len_X 0)
	   	(if (> YptL2 YptL1)
	         (setq Ang 90)
		 (setq Ang 270)
 But it also returns 'divide by zero' error.
Message 11 of 26
hmsilva
Your correct
(if (/= Len_X 0)
   (if (> YptL2 YptL1)
         (setq Ang 90)
(setq Ang 270)
but you'll need also to test further down in the code, the Len_X value, at
      (if (zerop Len_X)
Henrique
Message 12 of 26
Now this lisp looks like this:
(defun c:2
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
     ; (setq Ang (atan Len_Y Len_X)) ; if you pick two Points which create Vertical line, the Length_X =0 and in the ;CommandLine there is ""error: Divide by zero"
	(if (/= Len_X 0)
        (if (> YptL2 YptL1)
         (setq Ang 90)
         (setq Ang 270)
	     (if (minusp Ang) "-" "")
	     (angtos (abs Ang) angun 3)))
	        (if (zerop Len_X)
);defun
 But when I pick two points on the Line which Angle is 90, there is such prompt in CommandLine:
Command: 2
Downslope = 100.000%.
Length_X = 0.000.
Length_Y = 36.657.
Angle = 116.620 Degrees.
Length = 36.657.
Command:
What about this number? It should be equal 90, not 116.620. Is that because of 'angun 3'?
Message 13 of 26
hmsilva
Change the test, to
(if (/= Len_X 0)
          (if (> YptL2 YptL1)
            (setq Ang (* pi 0.5))
            (setq Ang (* pi 1.5))
Henrique
Message 14 of 26
I have solution for this problem.
And, what's more, I noticed, that there was one more not good made thing.
What was that thing?
So, if we draw line AB where point B is in the south-west direction from A, and if we click on this Line, in the Properties Palette (Ctrl+1) there will be an Angle value of some number between 180 and 270. And in this lisp which we had, in this situation in CommandLine there would be an value between (-180) and (-90) Degrees.
So i repair this thing too.
And now, here is our good made lisp:
(defun c:2
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
	(if (/= Len_X 0)
        (if (> YptL2 YptL1)
         (setq Ang (/ PI 2))       ; I gave PI/2 and 3PI/2 instead of 90 and 270, because Ang is an angle in Radians
         (setq Ang (* 3 (/ PI 2))
	(setq angstring
	  (strcat
	     (if (minusp Ang)
		 (angtos (- (* 2 PI) (abs Ang) ) angun 3) ; I gave 2PI-Ang instead of (-Ang) in order to have a value ;such like it would be in Properties Palette
	        (if (zerop Len_X)
);defun
Thank you all for help. Now we could enjoy it and inspect all things we need with this one lisp.
Message 15 of 26
hmsilva
Glad you have it sorted!
Henrique
Message 16 of 26
I noticed, that when I picked two points which create 'Line' which Angle Property is 90 or 270, in CommandLine there is prompt that Downslope= some very big number of %'s.
But it should prompt Downslope=100% for Angle=90 and -100% for Angle=270.
So I rewrote this lisp (instead of this I used this).
And now it looks like this:
(defun c:2231
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
	(if (/= Len_X 0)
      (if (> YptL2 YptL1)
         (setq Ang (* 3 (/ PI 2)))
		 (setq DownslopePercents (- 0 100))
	(setq angstring
	  (strcat
	     (if (minusp Ang)
;	        (if (zerop Len_X)
;        (setq DownslopePercents 100)
;        (setq DownslopePercents (* (/ Len_Y Len_X) 100))
);defun
But there is some error.
In CommandLine there is:
"; error: bad function: 0.329309"
And I don't know what the cause could be.
Could you tell me what I wrote wrong?
Message 17 of 26
hmsilva
Hi Damian,
at the momentdon't have AutoCAD to test your code, but in a quick read I have noticed that the test 'if' are not written correctly...
e.g.
 (if (/= Len_X 0)
in a 'if' function, we must have the
(if (test function)
(expression to be evaluated if not nil)
(expression to be evaluated if nil)
Henrique
Message 18 of 26
I add some ';' marks to modify my modified lisp (and now instead of this I use this). Now this lisp with ';' is working:
(defun c:234
  Len Len_X Len_Y
  ptL1 ptL2
    (progn
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
		 (= angun 1)
	    ((= angun 2)
	    ((= angun 3)
	    ((= angun 4)
	(if (/= Len_X 0)
      (if (> YptL2 YptL1)
;		 (setq DownslopePercents (- 0 100))
	(setq angstring
	  (strcat
	     (if (minusp Ang)
	        (if (zerop Len_X)
);defun
It might help to solve my problem.
Message 19 of 26
Not correnctly?
(if (condition)
    (then do this)
    (else do this)
I want to do two things in "then do this" part, and to do two things in "else do this" part.
(if (> YptL2 YptL1) ; condition
		( ; then
		) ; end of then
		( ; else
		) ; end of else
	  ); end of if
Maybe Autocad reads
as an argument for
(setq Ang (/ PI 2))
? But Autocad doesn't should read it that way...
Maybe in the 'if' statement, in both "then do this" part, and in "else do this" part, there should be only one thing to do?
Message 20 of 26
I see, that my statemant:
"Maybe in the 'if' statement, in both "then do this" part, and in "else do this" part, there should be only one thing to do?"
is correct.
I wrote second if, separately, specailly for 'Downslope':
(defun c:2
Len Len_X Len_Y
ptL1 ptL2
(progn
(setq Len
(sqrt
); sqrt
); Len
(= angun 1)
((= angun 2)
((= angun 3)
((= angun 4)
; First 'if', for 'Angle'
; (setq Ang (atan Len_Y Len_X)) ; if you pick two Points which create Vertical line, the Length_X =0 and in the CommandLine there is ""error: Divide by zero" (if (/= Len_X 0) ; ( (setq Ang (atan Len_Y Len_X)) ; (setq DownslopePercents (* (/ Len_Y Len_X) 100)) ; ) (if (> YptL2 YptL1) ; ( (setq Ang (/ PI 2)) ; I gave PI/2 and 3PI/2 instead of 90 and 270, because Ang is an angle in Radians ; (setq DownslopePercents 100) ; ) ; ( (setq Ang (* 3 (/ PI 2))) ; (setq DownslopePercents (- 0 100)) ; ) ) ) ; end of first 'if'
; second 'if', this time for 'Downslope' (if (/= Len_X 0) ; ( ; (setq Ang (atan Len_Y Len_X)) (setq DownslopePercents (* (/ Len_Y Len_X) 100)) ; ) (if (> YptL2 YptL1) ; ( ; (setq Ang (/ PI 2)) ; I gave PI/2 and 3PI/2 instead of 90 and 270, because Ang is an angle in Radians (setq DownslopePercents 100) ; ) ; ( ; (setq Ang (* 3 (/ PI 2))) (setq DownslopePercents (- 0 100)) ; ) ) ); end of second 'if' (setq angstring (strcat (if (minusp Ang) (angtos (- (* 2 PI) (abs Ang) ) angun 3) ; I gave 2PI-Ang instead of (-Ang) in order to have a value ;such like it would be in Properties Palette (angtos (abs Ang) angun 3) ) ) ) ;Len_Y/Len_X = DownslopePercents/100 ; (if (zerop Len_X) ; (setq DownslopePercents 100) ; (setq DownslopePercents (* (/ Len_Y Len_X) 100)) ; ) (setq DownslopePercents2string (rtos DownslopePercents 2 3)) ; Mode=2= Decimal, Precision=3 (princ (strcat "\nDownslope = " DownslopePercents2string "%.")) (princ (strcat "\nLength_X = " (rtos Len_X 2 3) ".")) (princ (strcat "\nLength_Y = " (rtos Len_Y 2 3) ".")) (princ (strcat "\nAngle = " angstring " " auni ".")) (princ (strcat "\nLength = " (rtos Len 2 3) ".")) (princ "\nPress [F2] to open and close results in CommandLine.") ) (prompt "\nYou did select the same point!!!") ) (princ);; exits quietly );defun
 And now it works good.
