Pick two Points to get Downslope in percents, prompted in CommandLine
Message 1 of 26
I wrote a lisp which calculates the downslope in percents and returns this downslope's value to CommandLine.
Here it is:
; DSE = DownSlopE
; DOWNSLOPE
(defun c:DOWNSLOPE
 (/ ptL1 ptL2 Len_X Len_Y Len Ang DownslopePercents)
 (setvar "cmdecho" 0)
 (setq ptL1 (getpoint "\nSpecify First Point to calculate Downslope: "))
 (setq ptL2 (getpoint "\nSpecify Second Point to calculate Downslope: "))
 (setq XptL1 (car ptL1))
 (setq YptL1 (cadr ptL1))
 (setq XptL2 (car ptL2))
 (setq YptL2 (cadr ptL2))
 (setq Len_X (- XptL2 XptL1))
 (setq Len_Y (- YptL2 YptL1))
; What if XptL1 = XptL2 --> Len_X=0?
; (setq Len
;  (sqrt
;   (+ (* Len_X Len_X) (* Len_Y Len_Y))
;  ); sqrt
; ); Len
; (setq Ang (atan Len_Y Len_X))
;Len_Y/Len_X = DownslopePercents/100
 (setq DownslopePercents (* (/ Len_Y Len_X) 100))
 (setq DownslopePercents2string (rtos DownslopePercents 2 3)); Mode=2=Engineering, Precision=3
 (princ "\nDownslope = ")
 (princ "%.")
; (princ "\nAngle = ")
; Length
; (princ " <Here should be current angle units. Should I type 'getvar AUNITS?'>.")
; (princ "\nLength = ")
; Length
; (princ ".")
);defun
Some parts of this lisp I ignore with ';', because they will be investigated in other cases - on ground of this lisp I want to write lisps which return to CommandLine Distance and Angle between two picked Points. And I can't do them using 'getdist' and 'getangle', because the user would type his own value for Distance and Angle.
So returning to the main topic: This lisp doesn't work properly.
In the CommandLine it returns:
Command: DOWNSLOPE
Downslope = %."%."
Could you please tell me why it doesn't work in way which I suspected?
Replies (25)
Message 21 of 26
hmsilva
Glad you have it sorted!
Henrique
Message 22 of 26
So I conclude in one 'if' statemetn I can write only one thing to do as 'then' and only one thing to do as 'else'?
I am right?
Message 23 of 26
hmsilva
I am right?
No, you can write one statement.
e.g.
(if (xxxxx)
 (progn
  (do this)
(do n times as needed) (do that) );end progn from test not nil (progn (do this)
(do n times as needed) (do that) );end progn from test nil ); end if
 >> progn <<
Henrique
Message 24 of 26
Thank you very much!
That is the next, new interesting thing which I just have learned.
I noticed 'progn' on the beginning if this lisp
(if (and (setq ptL1 (getpoint "\nSpecify First Point to calculate Downslope: "))
	   (not (equal ptL1 ptL2 1e-8))
    (progn
 but I thought it is optional thing and I could not write it.
But now I know I was wrong.
http://www.afralisp.net/autolisp/tutorials/cond-vs-if.php
http://www.afralisp.net/autolisp/tutorials/conditionals.php
Message 25 of 26
hmsilva
You're welcome, Damian!
Henrique
Message 26 of 26
I modified this lisp and now it is working properly.
So, here is the next version of this lisp:
; 2 -INFO ABOUT LINE BETWEEN TWO points
(defun c:23456
 (/ angstring angun auni Ang
  DownslopePercents DownslopePercents2string
  Len Len_X Len_Y
  ptL1 ptL2
  XptL1 XptL2 YptL1 YptL2
    (progn
      ;; (setq len (distance ptL1 ptL2))
      (setq Len
	     (sqrt
	     ); sqrt
      ); Len
      (setq angun (getvar 'aunits))
      (cond ((or (= angun 0)
		 (= angun 1)
	     (setq auni "Degrees")
	    ((= angun 2)
	     (setq auni "Gradians")
	    ((= angun 3)
	     (setq auni "Radians")
	    ((= angun 4)
	     (setq auni "Surveyor")
     ; (setq Ang (atan Len_Y Len_X)) ; if you pick two Points which create Vertical line, the Length_X =0 and in the CommandLine there is ""error: Divide by zero"
	(if (/= Len_X 0)
	  (progn
	    (setq DownslopePercents (* (/ Len_Y Len_X) 100)) ; DownslopePercents = tan(Ang) * 100% = (Len_Y / Len_X) * 100% ; It is another way to calculate DownslopePercents
      (if (> YptL2 YptL1)
		(progn
         (setq Ang (/ PI 2))       ; I gave PI/2 and 3PI/2 instead of 90 and 270, because Ang is an angle in Radians
		 (setq DownslopePercents "plus infinity") ; I used strings of "plus infinity" and "minus infinity" instead of numbers 100 and -100. Earlier I thought that Downslope changes from 0% to 100% (and of course I was totally wrong) so that's why there were values of 100 and -100.
		 (setq DownslopePercents2string DownslopePercents)
		(progn
		 (setq Ang (* 3 (/ PI 2)))
		 (setq DownslopePercents "minus infinity")
	(setq angstring
	  (strcat
	     (if (minusp Ang)
		 (angtos (- (* 2 PI) (abs Ang) ) angun 3) ; I gave 2PI-Ang instead of (-Ang) in order to have a value ;such like it would be in Properties Palette
		 (angtos (abs Ang) angun 3)
;	        (if (zerop Len_X)
;        (setq DownslopePercents 100)
;        (setq DownslopePercents (* (/ Len_Y Len_X) 100))
;	  		(setq DownslopePercents2string (rtos DownslopePercents 2 3)) ; This expresiion I copied into three separate cases above in 'if'
      ; Mode=2= Decimal, Precision=3
      (princ (strcat "\nDownslope = " DownslopePercents2string  " %.")) ; I gave space bar here to not have prompts "minus infinity%"
	  (princ (strcat "\nLength_X = " (rtos Len_X 2 3) "."))
	  (princ (strcat "\nLength_Y = " (rtos Len_Y 2 3) "."))
      (princ (strcat "\nAngle = " angstring " " auni "."))
      (princ (strcat "\nLength = " (rtos Len 2 3) "."))
	  (princ "\nPress [F2] to open and close results in CommandLine.")
    (prompt "\nYou did select the same point!!!")
(princ);; exits quietly
);defun
I have learned so much only modifing this one lisp.
I am really proud of create it, because it seams to be small, but it is very useful!
I checked the Downslope of the road on bridge which I design.
I edited this lisp so many times... But still I could not say that it is the final version.
