New Lisp Routine help
How do I create a lisp routine that draws a circle, then inscribes an equilateral triangle and circumscribes a square while only prompting the user to chose a center point and radius for the circle?  I am having trouble figuring out the lisp routine.
Shneuph
Maybe post what you have got so far and we can recommend changes?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
this is all I have
Ranjit_Singh
It's pretty simple using native Autocad commands, if I understand you correct
(defun c:somefunc  (/ cen rad)
 (command "._circle" (setq cen (getpoint "\nSpecify center point: ")) pause)
 (command "._polygon" 3 "_non" cen "_i" "_non" (setq rad (cdr (assoc 40 (entget (entlast))))) "._polygon" 4 "_non" cen "_c" "_non" rad))
This is great! That's exactly what I was looking for. Thank you, your help is very much appreciated.
Kent1Cooper
If you do this often, I would suggest a little drawing of that with a 1-unit radius in the Circle.  Then you can just Insert it, with the scale factors being the desired radius -- a one-command rather than three-command process.
Kent Cooper, AIA
