Named View assign UCS
Baker_ADG
Message 1 of 8
Baker_ADG
Forgive my archaic lisp routine, feel free to help and refine it..
But I was wondering if there was a way to assign a named UCS to a named view through the command line.  (about line 37)
(defun c:NVVF (/ echo ept pt1 pt2 pt3 tx1 *ERROR*)
(defun *Error* (strErr)
  (setvar "expert" ept)
  (setvar "CmdEcho" echo)
  (princ)
 ) ;_ closes ERROR EXCEPTION defun
 (setq ;saves current SYSTEM VARIABLES
  ept (getvar "expert")
  echo (getvar "CmdEcho")
(setvar "expert" 4)
(setvar "CmdEcho" 0)
(Command "_.ucs" "world")
(setq
pt1 (GETPOINT "\nPick Bottom Left Corner of View Frame: ")
pt2 (GETPOINT "\nPick Bottom Right Corner of View Frame: ")
(command "ucs" "3" pt1 pt2 "")
(setq
pt3 (GETPOINT "\nPick Top Right Corner of View Frame: ")
tx1 (GETSTRING T "\nEnter view name to save: ")
(command "_.ucs" "named" "save" tx1)
(COMMAND "PLAN" "")
(COMMAND "ZOOM" "0,0" pt3)
(command "-view" "W" tx1 "0,0" pt3)
(princ "\n***Named View Created***")
   (*error* nil)
;quiet exit
 (princ)
Jon Baker | Land Development & Infrastructure Design Manager
Alignment Design Group | Denver | Colorado
Civil 3D 2025 | Windows 11
Replies (7)
Message 2 of 8
Moshe-A
@Baker_ADG
Command: -VIEW
Enter an option [?/Delete/Orthographic/Restore/Save/sEttings/Window]: sEttings
Enter an option [Background/Categorize/Layer snapshot/live Section/Ucs/Visual style]: ucs
Save current UCS with named views?[Yes/No]<Yes>:
moshe
Message 3 of 8
Baker_ADG
I've tried that.. and it does not actually assign the UCS to the view.
Message 4 of 8
Baker_ADG
my original line of code: (command "-view" "settings" "ucs" "yes" "" "W" tx1 "0,0" pt3)
Message 5 of 8
Sea-Haven
Do you want multiple layouts that are rotated automatically as you walk along a pline ? Noted "Land development".
Message 6 of 8
Moshe-A
@Baker_ADG ,
give this a try, works for me 😀
Moshe
(defun c:nvvf (/ *error* ; local function
                 echo ept pt1 pt2 pt3 tx1)
 (defun *error* (msg)
  (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (princ (strcat "\nError: " msg))
  (princ)
 (setvar "CmdEcho" 1)
 (command "._undo" "_begin")
 (setq ept (getvar "expert")
 (setvar "expert" 4)
 (if (and
      (setq pt1 (getpoint "\nPick Bottom Left Corner of View Frame: "))
      (setq pt2 (getpoint "\nPick Bottom Right Corner of View Frame: "))
      (not (command "._ucs" "3" pt1 pt2 ""))
      (setq pt3 (getpoint "\nPick Top Right Corner of View Frame: "))
      (not (eq  (setq tx1 (getstring t "\nEnter view name to save: ")) ""))
  (progn
   (command "_.ucs" "_named" "_save" tx1)
   (command "._plan" "")
   (command "._zoom" "0,0" pt3)
 ; (command "-view" "W" tx1 "0,0" pt3)
   (command "._view" "_save" tx1)
  ); progn
 ); if
 (command ".undo" "_end")
 (setvar "cmdecho" echo)
 (princ)
Message 7 of 8
Baker_ADG
perfect!!!
Thank you!!
Message 8 of 8
Sea-Haven
Appreciate pick 2 points for view but, red rectangles follow a line or pline at title/layout scale, next step is make all layouts with view twisted. Made like 50 layouts 1 go. Just run again for multiple line/plines.
