Select similar within a selected entity
Millwood-k
Millwood-k
Hi guys
When using "select similar" command, it selected everything similar on the model space,
However, I am traying to find a way to use select similar command only on a specific selection I seize.
Like we have this option with "find and replace" command
Thanks in advance
AVCPlugins
You can first isolate the desired objects (_isolate), and then look for similar ones among them.
And basically, I can add an option like this to the Select Same Objects command especially for you.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
paullimapa
already asked and solved here:
Re: select similar by window selection ? - Autodesk Community - AutoCAD
This reply has been edited by the moderation team as the legacy links were no longer valid
Paul Li
IT Specialist
@The Office
Millwood-k
Thanks for the answer
isolate works
Select Same Objects has multiple options and  it's nice too. especially 3d or complex files
