Correct forwarding of arguments throught several functions
denys_gorkovchuk
denys_gorkovchuk
Hi comunity!
I have several functions which work together. Simplified code is here:
(defun loop (sset functiontext / entity) ;receive selection set and text of function as input and do that function on every object of selection set
   (if sset
      (progn
         ;(loop code for loop through every object of selection set
            (eval (read functiontext )) ;evaluate function within loop
         ;)end of loop
      );progn
   );if
); defun
(defun mainfunction (entity point1 point2 param / ) ; main function, which will be evaluated within the loop
(command "_POINTCLOUDCROP" entity point1 point2 param)
);defun
(defun C:test (/ ss point1 point2 param func) ;command, which should join everything together and receive input from user
   (setq ss (ssget)) ;select objects
   (setq point1 (getpoint "\nSpecify first corner point")) ;specify arguments
   (setq point2 (getcorner point1 "\nSpecify second corner point :"))
   (setq param "_Inside")
   (setq func (strcat "(mainfunction entity (list " (vl-princ-to-string point1) ") " (vl-princ-to-string point2) " \"" (vl-princ-to-string param ) "\")" )) ;build a text of function to execute
   (if ss
      (loop ss func) ;start loop
   );if
);defun
I assume there is somewhere error in building the text of function to execute. Similar simple functions with 1 argument works fine, but here i need to transfer several arguments: lists (points) and string. And I got errors "bad function", "unknown command".
I believe there is some very simple solution with correct syntax, but can't find that in manuals.
Can you help me?
paullimapa
in c:test with this line of code where is entity defined?
Paul Li
IT Specialist
@The Office
denys_gorkovchuk
entity is not defined in C:test. Here it is just a string value.
Entity is defined in mainfunction, so when function text is evaluated in mainfunction it recognize this string as argument, so everything works.
When function is very simple, only with entity, - it works perfectly. But when I need more arguments, then I get errors. I assume the problem is in transferring the lists.
denys_gorkovchuk
ok, now I have found my own error. I have forwarded lists and string. And in both cases i used vl-princ-to-string to convert list to string for strcat. but param was already a string, so there was no need to use vl-princ-to-string. I have removed it and everything works now.
paullimapa
when I run test after selecting objects and the corners of the window, AutoCAD always returns
error: bad function: ####  where ## is a real number that varies
I still don't know what you're passing as the entity
This line of code equates a call to mainfunction sub routine with entity as one of the arguments:
Then when you pass func as an argument to your loop function all you are doing is evaluated the expression as code:
This then jumps to your mainfunction sub routine with still entity as the first argument which is never defined.
Paul Li
IT Specialist
@The Office
Moshe-A
@denys_gorkovchuk  hi,
to gather symbols into one variable, put them is a list as quoted items. see line 44. at the point you want to call the  function, use (eval) see line 21.
a good coding at the beginning of command is to collect all data inputs and validate them so if user miss some, the command will exit without any errors. this saves you from validating the same variables along the road.
note the 'eph variable which is an Ename Place Holder to be substitute by entity.  lines 34, 16
enjoy
Moshe
(defun mainfunction (entity point1 point2 param)
);defun
; receive selection set and text of function as input and do that function on every object of selection set
(defun loop (sset functiontext / i entity)
 ; sset is check in c:test
 ; (if sset
 ;  (progn
  ; (eval (read functiontext )) ;evaluate function within loop
   ; (loop code for loop through every object of selection set
   (setq i -1)
   (repeat (sslength sset)
    (setq i (1+ i))
    (setq entity (ssname sset i))
    (setq functiontext (append (reverse (cdr (member 'eph (reverse func)))) (list 'entity) (cdr (member 'eph func)))) ; replace 'eph with entity
    (eval functiontext)
   ); repeat - end of loop
;  );progn
; );if
); defun
; command, which should join everything together and receive input from user
(defun c:test (/ ss point1 point2 entity param eph func)
 (if (and
       (setq point1 (getpoint "\nSpecify first corner point")) ; specify arguments
  (progn
   (setq entity (ssname ss 0))
 ; (setq func (strcat "(mainfunction entity (list " (vl-princ-to-string point1) ") " (vl-princ-to-string point2) " \"" (vl-princ-to-string param ) "\")" ))
   (setq eph "enamePlaceHolder")
   ; build a text of function to execute
   (setq func (list 'mainfunction 'eph 'point1 'point2 'param))
 ;| (if ss
    (loop ss func)
  ); progn
 ); if
);defun
