@mattv4F4AG wrote:
@Kent1Cooper If its not too much trouble, could you help me to include the ctrl-z command during the routine to undo a color change if I accidently click a wrong line or block during the routine?
I stole and adjusted that functionality from my ReverseDirection.lsp routine, >here<. It seems to work here, in very limited testing:
;|Change Layer Color by picking object / nested object, but if nested
object's Layer is 0, lowest-level non-0 nesting Layer up from there.
RJP » 2018-08-17, enhanced by Kent Cooper 4 Nov 2022
to prevent of change to nested Layer 0, add individual Undo within.
(defun C:CLC (/ c d n done esel ent edata elay layc nestlist nlayc)
(or (getenv "clc") (setenv "clc" "(62 . 1)")); red first-use default
(cond
((setq c (acad_truecolordlg (read (getenv "clc")))); get color
(setenv "clc" (vl-prin1-to-string (last c)))
(setq
d (vla-get-activedocument (vlax-get-acad-object))
n 0 ; internal Undo counter
); setq
(while (not done)
(setvar 'errno 0)
(if (> n 0) (initget "Undo")); Undo option only if things to undo
(setq esel
(nentsel
(strcat
"\nSelect object to change Layer color, or "
(if (> n 0) "[Undo] " ""); Undo option only if things to undo
"<exit>: "
); strcat
); entsel
); setq
(cond ; overall object-selection or Undo option
((= esel "Undo")
(setq n (1- n))
(command "_.undo" "_back"); revert last color change
); Undo condition
( ; test for selection, unlocked Layer
(and
(= (getvar 'errno) 0); picked something
(setq
ent (car esel)
edata (entget ent)
elay (cdr (assoc 8 edata))
); setq
(= (logand 4 (cdr (assoc 70 (tblsearch "layer" elay)))) 0)
; 0 = unlocked, 4 = locked
); and
(command "_.undo" "_mark")
(setq layc ; = LAYer to change Color of
(if (= elay "0"); on Layer 0
(cond ; then
((> (length esel) 2); nested entity [other than Attribute] in Block/Xref
(setq nestlist (last (nentselp (cadr esel)))); stack of references it's nested in
(while
(and
nestlist ; still nesting level(s) remaining
(= (setq nlayc (cdr (assoc 8 (entget (car nestlist))))) "0"); = Nested [non-0] LAYer to change Color of
); and
(setq nestlist (cdr nestlist)); if was 0, move up a level if present
); while
nlayc
; lowest-level non-0 Layer of nested or containing reference(s); 0 if that all the way up
); non-Attribute nested entity on Layer 0 condition
((= (cdr (assoc 0 edata)) "ATTRIB"); Attribute in Block
(cdr (assoc 8 (entget (cdr (assoc 330 edata))))); Block's Layer
); Attribute on Layer 0 condition
("0"); none-of-the-above condition
); cond - then
elay; else - non-0 Layer of entity/nested entity
); if & layc
); setq
(if (= (logand 4 (cdr (assoc 70 (tblsearch "layer" layc)))) 0); unlocked
(progn ; then
(entmod (append (entget (tblobjname "layer" layc)) c))
(vla-regen d acactiveviewport)
(setq n (1+ n)); for Undo option
); progn
(alert "\nObject's lowest-nested non-0 Layer is locked."); else
); if
); picked-something condition
((= (getvar 'errno) 0); picked something, but ....
(prompt "\nThat object is on a locked Layer --")
); non-qualifying condition
((= (getvar 'errno) 7) (prompt "\nNothing selected --"))
((setq done T)); Enter/space at Select-object prompt [errno = 52]; stop (while) loop
); cond -- selection or U or <exit>
); while
); got-color condition
); cond
(princ)
); defun
(vl-load-com)
Kent Cooper, AIA
