Modification on Given LISP
fkp7057
Message 1 of 23
fkp7057
Hello, I found below the old lisp routine in this forum.
this lisp counts specific blocks from the entire drawing. But want it to count only block which are in model space.
Link of the original post  : LINK
(defun c:recount (/ block_list cnt env_name)
(setq block_list
(list
(cons '2 "1")
(cons '2 "2")
(cons '2 "3")
(foreach i block_list
(if
(setq ss (ssget "X" (list '(0 . "INSERT") i)))
(progn
(setq
cnt (itoa (sslength ss))
env_name (strcat "BLOCK_COUNT_" (cdr i))
(setenv env_name cnt)
(princ (strcat "\nSet " env_name " to " cnt))
(progn
(setq
cnt "0"
(command "_REGEN") ;_refreshes field values
(princ)
Replies (22)
Message 21 of 23
fkp7057
Ok, then what is the difference ?... mean how can this help me in compare to previous code?
Message 22 of 23
Sea-Haven
There are ways of counting blocks in one go using a single ssget filter of block names s1,s2,s3 I guess that is what I was getting at, lee-mac has a good block counter you would just modify the selection filter rather than pick, to uses known block names.
I have count blocks with attributes but it sorts on block names and attributes for the count up to 5 attributes deep.
Message 23 of 23
fkp7057
@hak_vz
plze chek this new post.
little further modification is required here .
Link
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/block-count-and-link-with-field-text...
