A field exression as formula, adding two decimals is not being evaluated when copied to an attribute or text. An example:
%<\AcExpr (%<\_FldPtr 3064644751888>% + %<\_FldPtr 3064644752208>%) \f "%lu2%ct8[0.01]">%
There is always an "####". Why is it so? One of the values is a BlockPlaceholder. Maybe it is the reason? However, defining the formula via the gui works fine. But when copying and pasting the field expression, it fails to evaluate.
I am writing a lisp routine to copy field expressions to other attributes which works well for single, not formula calculated values. Any help is appreciated.
(By the way. I don't know how to remove this post from the Dynamic-Blocks-Forum, posting it there beforehand unintended...)
