Modification on Given LISP
fkp7057
Message 1 of 23
fkp7057
Hello, I found below the old lisp routine in this forum.
this lisp counts specific blocks from the entire drawing. But want it to count only block which are in model space.
Link of the original post  : LINK
(defun c:recount (/ block_list cnt env_name)
(setq block_list
(list
(cons '2 "1")
(cons '2 "2")
(cons '2 "3")
(foreach i block_list
(if
(setq ss (ssget "X" (list '(0 . "INSERT") i)))
(progn
(setq
cnt (itoa (sslength ss))
env_name (strcat "BLOCK_COUNT_" (cdr i))
(setenv env_name cnt)
(princ (strcat "\nSet " env_name " to " cnt))
(progn
(setq
cnt "0"
(command "_REGEN") ;_refreshes field values
(princ)
Replies (22)
Message 2 of 23
hak_vz
@fkp7057
For a start change this line
to
(setq ss (ssget "X" (list '(0 . "INSERT")(410 . "Model"))))
Miljenko Hatlak
Message 3 of 23
Sea-Haven
Like hak_vz if you want only in a layout use (cons 410 (getvar 'ctab)) can use in a loop finding in all layouts, but "Model" is still a valid ctab name.
Message 4 of 23
fkp7057
I have updated as per your suggestion, but still, this lisp count block which is in layout space.
Message 5 of 23
fkp7057
Tried this way too but, the block counts come 93 for all blocks, but actually, there are less than 10 countss of a particular block
Message 6 of 23
hak_vz
Sorry It was early morning and I just copied construction from the code you have attached.
Try this
(setq ss (ssget "_X" '((0 . "INSERT")(410 . "Model"))))
Tested and it works OK.
Or you can use
(setq ss (ssget "_A" '((0 . "INSERT")(410 . "Model"))))
Similar to the "X" mode string but excludes objects on frozen layers. Selects all objects on thawed layers.
Miljenko Hatlak
Message 7 of 23
fkp7057
see the attached snap, it is loaded and worked as well but still, it is counting blocks that are in layout space.
might be the above error caused the problem.
Message 8 of 23
hak_vz
Question is is this code useful for what you want to use it.
Try to define your problem, not in a few words, but thoroughly.  Do you want to count all blocks in model space or just particular on i.e defined by its name. Since you are electrical engineer this would be like: count all blocks (inserts) named "BULB" or "FUSE".... .
Code can than be created for your specific case or better for general usage. Reusing old code isn't always best options if this code is created for different purpose.
In some case property tab can give you meaningful result without using autolisp. Check this blog post
Miljenko Hatlak
Message 9 of 23
fkp7057
My objective is that the quantity of the particular block needs to update automatically as per block count in model space my drawing contains more than 25-30 different blocks.
i used to show Legend/description and its quantity as per the below image.
that legend table I kept at layout/paper space.
given block work correctly but it also counts block which is in layout space. and I m having multiple sheets and going to put that table in all the sheets.
then this quantity also going to increase.
what I want is this code count only blocks that are in model space so in field text it shows the correct no. of the count.
as of now, I am using the method shown in the link which I have shared in an earlier msg.
here below I am pasting the code that I am going to use it.
(setq block_list
(list
 (cons '2 "S1")
 (cons '2 "S2")
 (cons '2 "S3")
 (cons '2 "S4")
 (cons '2 "S5")
 (cons '2 "S6")
 (cons '2 "S7")
 (cons '2 "S8")
 (cons '2 "S9")
 (cons '2 "S10")
 (cons '2 "S11")
 (cons '2 "S13")
 (cons '2 "S14")
 (cons '2 "S15")
 (cons '2 "S16")
 (cons '2 "S17")
 (cons '2 "S18")
 (cons '2 "S19")
 (cons '2 "S20")
 (cons '2 "S21")
 (cons '2 "NORMAL PUSH BUTTON")
 (cons '2 "NORMAL PUSH BUTTON (W)")
 (cons '2 "NORMAL PUSH BUTTON (FLAME PROOF)")
 (cons '2 "LDB")
 (cons '2 "ELDB")
 (cons '2 "SPDB")
 (cons '2 "ESPDB")
 (cons '2 "ESPDB")
 (cons '2 "DB")
 (cons '2 "JB")
 (cons '2 "MODULE_PLATE")
(if
(progn
(setq
(progn
(setq
cnt "0"
(princ)
Message 10 of 23
fkp7057
I am aware that there are many other and easy ways to count the block.
some time drawing not finished in one go we need to keep updating this qty. sometimes we forgot to update qty.
so here I want to standardize/ wanted to do some automation thing for my department.
progressively I will add more and more blocks so this 1 lisp help solve the purpose.
going to set up a template kind of thing. which will be a great help for our teammates.
Message 11 of 23
hak_vz
@fkp7057 Try this . If it wont work I'll check it later today. I'm Currently at work
	(setq block_list
		'("S1" "S2" "S3" "S4" "S5" "S6" "S7" "S8" "S9" "S10" "S11" "S13" "S14" "S15" "S16" "S17"
		"S18" "S19" "S20" "S21" "NORMAL PUSH BUTTON" "NORMAL PUSH BUTTON (W)" "NORMAL PUSH BUTTON (FLAME PROOF)"
		"LDB" "ELDB" "SPDB" "ESPDB" "ESPDB" "DB" "JB" "MODULE_PLATE")
		(if
			(setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 410 "Model") (cons 2 i))))
		(progn
		(setq
		(progn
		(setq
		cnt "0"
	(princ)
Miljenko Hatlak
Message 12 of 23
fkp7057
not worked 😐
I am using Autocad on windows10 OS.
Message 13 of 23
hak_vz
@fkp7057  Attach sample dwg with some blocks in model space and layouts, named as in your lisp so I can check how code works.
Miljenko Hatlak
Message 14 of 23
fkp7057
PFA attached a Sample CAD file along with the LISP file which I am using it.
In the Drawing file you can see that block name "S1" are 5 in model space but in layout space (qty. table),  its total qty shows 8 (5 in model space +3 which are in 3 layout space)
Message 15 of 23
hak_vz
Tested and it works OK at my side
(defun c:recount (/ block_list cnt env_name ss)
(setq block_list
(list
 (cons 2 "S1")
 (cons 2 "S2")
 (cons 2 "S3")
 (cons 2 "S4")
 (cons 2 "S5")
 (cons 2 "S6")
 (cons 2 "S7")
 (cons 2 "S8")
 (cons 2 "S9")
 (cons 2 "S10")
 (cons 2 "S11")
 (cons 2 "S13")
 (cons 2 "S14")
 (cons 2 "S15")
 (cons 2 "S16")
 (cons 2 "S17")
 (cons 2 "S18")
 (cons 2 "S19")
 (cons 2 "S20")
 (cons 2 "S21")
 (cons 2 "NORMAL PUSH BUTTON")
 (cons 2 "NORMAL PUSH BUTTON (W)")
 (cons 2 "NORMAL PUSH BUTTON (FLAME PROOF)")
 (cons 2 "LDB")
 (cons 2 "ELDB")
 (cons 2 "SPDB")
 (cons 2 "ESPDB")
 (cons 2 "ESPDB")
 (cons 2 "DB")
 (cons 2 "JB")
 (cons 2 "MODULE_PLATE")
(if
(setq ss (ssget "X" (list (cons 0 "INSERT") (cons 410 "Model") i)))
(progn
(setq
(progn
(setq
cnt "0"
(princ)
Miljenko Hatlak
Message 16 of 23
fkp7057
Thank you very much.
finally, it worked...
Message 17 of 23
hak_vz
I am glad I was able to help.
Miljenko Hatlak
Message 18 of 23
Sea-Haven
No need for cons 2's a ssget accepts (cons 2 "s1,s2,s3,s4,s5.....) or a foreach use ssget with 1 block name and then use ssadd to add to master selection.
Message 19 of 23
fkp7057
can you explain a little bit more as I am not good at lisp coding?
I am not able to understand what you want to say.
Message 20 of 23
Sea-Haven
Like Hak_vz used a foreach for block names (setq ss "X" (list(cons 0 "INSERT") (cons 2 "s1,s2,s3,s4....")))
