Linking a FIELD to a Block Count
seedstudiolandscapedesign
Message 1 of 40
Is it possible to display an autoupdating block count by using a FIELD in a TABLE?
I've looked but I can't seem to find the information, any input is appreciated.
Replies (39)
Message 2 of 40
maxim_k
Hi Steve,
There is no direct way in plain AutoCAD and especially in AutoCAD for Mac. If you have full AutoCAD version (not LT) you can use workaround with small AitoLISP routine and DIESEL expression in the Field.
Are you using AutoCAD LT?
If so, than it seems to be impossible to accomplish this task, even with workaround I mentioned above.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 40
Hi Maxim,
I'm on the full version.  Would the routine go in the Field Expression box area of the FIELD command popup?
My experience is very limited with coding.  What is the difference between DIESEL and AutoLISP and which would be better in this scenario?
Message 4 of 40
maxim_k
You cannot use AutoLISP expressions in fields, but you can use DIESEL expressions.
The idea is to assign a number of occurrences of the block to variable and show the value of this variable in the FIELD using DIESEL expression.
Look at this discussion:
https://www.theswamp.org/index.php?topic=15926.0
Here is another discussion:
http://www.arch-pub.com/DIESEL-Expression-to-return-occurances-of-blocks_10221422.html
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 40
Hi Maxim,
Thanks for directing me to these resources, they appear to do exactly what I need.
Unfortunately I am a total newbie to AutoLISP and was unable to get Mark's routine over at theswamp.org you referenced here to work.  I'll repost my edited version and hopefully you wouldn't mind pointing out where I went wrong.
Retracing my steps:
1) Modified the code to count multiple blocks and saved as BLOCK_COUNT.lsp, here's my modified version (I renamed the test blocks 1 2 and 3:
(defun c:recount (/ block_list cnt env_name)
(setq block_list
(list
(cons '2 "1")
(cons '2 "2")
(cons '2 "3")
(foreach i block_list
(if
(setq ss (ssget "X" (list '(0 . "INSERT") i)))
(progn
(setq
cnt (itoa (sslength ss))
env_name (strcat "BLOCK_COUNT_" (cdr i))
(setenv env_name cnt)
(princ (strcat "\nSet " env_name " to " cnt))
(princ)
2) used the APPLOAD command to load the routine named BLOCK_COUNT.lsp
3) inserted three fields into my drawing using the DieselExpression type with the following expressions:
$(getenv, BLOCK_COUNT_1)
$(getenv, BLOCK_COUNT_2)
$(getenv, BLOCK_COUNT_3)
4) ran the command UPDATEFIELD
... and nothing happened.
Any help would be greatly appreciated 🙂
Message 6 of 40
maxim_k
Hi Steve,
Everything works fine on my side. Verify that the blocks in your drawing have the names "1", "2" and "3", as the routine counts blocks only with these names.
I just added one line to the AutoLISP routine (REGEN command) in order to refresh fields values within the routine, so you don't need to use UPDATEFIELD command for each field after recounting blocks.
(setq block_list
 (list
 (cons '2 "1")
 (cons '2 "2")
 (cons '2 "3")
 (if
 (progn
 (setq
 (command "_REGEN") ;_refreshes field values
 (princ)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 40
Hi Maxim,
I've tried your updated routine and attempted to update the FIELDs again but I still cannot get a number output.  I only see "- - - -" in the FIELD, both when I insert it and after updating.
Are you using the routine in AutoCAD for Mac?
Message 8 of 40
maxim_k
Yes, it works in AutoCAD for Mac - I have tested it in 2016 version.
Can you attach here the drawing file (with blocks and inserted fields) where you tested this routine?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 40
Sure, see attached.
Message 10 of 40
maxim_k
Try this:
at the command prompt type:
(setenv "BLOCK_COUNT_1" "10")
than hit Return.
Now type:
(getenv "BLOCK_COUNT_1")
and hit Return.
The output in the command window should be:
Command: (setenv "BLOCK_COUNT_1" "10")
"10"
Command: (getenv "BLOCK_COUNT_1")
"10"
Command:
What do you see on your side?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 40
Yes, I see:
"10"
"10"
Message 12 of 40
maxim_k
Than I cannot understand why fields on your side are not updated.
As I wrote before, on my side everything works in your drawing:
Double check DIESEL expressions in the fields:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 40
Thanks for the video, when I type RECOUNT the FIELDs do indeed update correctly.
I was using the commands UPDATEFIELD and REGEN, why wouldn't these commands also update the count?  Should I update my FIELDEVAL setting (currently at 31)?
Message 14 of 40
maxim_k
RECOUNT calls AutoLISP routine which calculates block instances, keeps the number of the blocks in the AutoCAD preferences file (environment variables) and then updates the fields according to the calculations.
REGEN and UPDATEFIELD knows nothing about the blocks in the drawing, so the cannot change fields according to the number of blocks.
When you load AutoLISP routine, it doesn't run immediately, you need to call it with RECOUNT command each time you need to recalculate the number of blocks.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 40
Thanks for clarifying, this little nugget of code will make my workflow quite a bit smoother.
Thank you Maxim for all your help 🙂
Message 16 of 40
Hi Maxim,
One more question, is there any way to modify the routine to show "0" if no blocks of a particular name are found?  Currently if you erase all of say block 3 and RECOUNT, the FIELD will show the previous count total instead of updating to "0".
Message 17 of 40
maxim_k
Hi Steve,
Try this:
(setq block_list
(list
(cons '2 "1")
(cons '2 "2")
(cons '2 "3")
(if
(progn
(setq
(progn
(setq
cnt "0"
(princ)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 40
Works like a charm.  I can't thank you enough Maxim, cheers 🙂
Message 19 of 40
Hello maxim_k!
I need to count the blocks through an attribute called LUM, how can I do it?
I have the blocks like this:
Name: 03.6572.40 (The manufacturer code, FLOS in this case)
Attribute "LUM": I rename the field with L1, L2, L3...
Thank you very much!
Message 20 of 40
Use data extraction method to update block count
after updating blocks update data table
