Linking a FIELD to a Block Count
seedstudiolandscapedesign
Message 1 of 40
Is it possible to display an autoupdating block count by using a FIELD in a TABLE?
I've looked but I can't seem to find the information, any input is appreciated.
Replies (39)
Message 21 of 40
maxim_k
Welcome to Autodesk Forums!
Hi Moin,
>>>>>Use data extraction method to update block count after updating blocks update data table
I'm afraid it is not possible in AutoCAD for Mac, only on PC side you can link extracted data to a table in the drawing.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 40
prousseauCQJ6U
I know it's already been 3 years, but is there a way to make this work with dynamic blocks?
Message 23 of 40
jimmykta
This is awesome, thank you. Is there a way to do the same but count the blocks from an xref file instead from a live file? Thanks!
Message 24 of 40
maxim_k
Hi Jimmy,
Just open externaly referenced drawing and count blocks in it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 25 of 40
Hi, I am using Audodesk Civil 3D 2019. I've been using the recount.lsp to link a field to a block count for a while and it works great with one exception that the field value resets to zero at some unknown time. For example, I have a block as a legend item and saved as an xref. Let's say I have 10 blocks and the field correctly counts 10 blocks; great it works. However, the field then somehow resets by itself to a zero value. Even though I haven't added or subtracted any blocks from that drawing, the only way to get the count is to type recount as regen doesn't update the count either. This lisp works great in counting my specified blocks but the issue is that I can't seem to keep the field value as it resets to zero. Is there a way to prevent autocad from resetting the value to zero and to keep the current count of the blocks running? I would really appreciate a solution. Thank you.
Message 26 of 40
maxim_k
Hi @Anonymous,
You are posting in AutoCAD for Mac Forum, but ask about Civil 3D.
Civil 3D Forum is here:
https://forums.autodesk.com/t5/civil-3d-forum/bd-p/66
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 27 of 40
Hey,
Is there a way to edit this to work with dynamic blocks? I am a total noob at lisp? Much thanks 🙂
Message 28 of 40
That’s a great question. It doesn’t seem to work for me. Anyone else?
Message 29 of 40
pendean
Community Legend
Community Legend
It depends on what the FIELD is counting... Most likely not.
FYI the dedicated dynamic blocks forum is here, why don't you start your own topic there for help https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154
Message 30 of 40
Thanks for your fast reply. Is there a solution for my question as I also work with this lisp on my AutoCAD for Mac? I understand that a solution for this platform may not work elsewhere. So I would be asking the same question specific to AutoCAD for Mac. Is there a solution so that the field does not reset itself to zero? Thank you
Message 31 of 40
yael.vsh
Hi Maxim,
Your answers in this thread were very helpful.
I was able to successfully implement the solution in the thread you provided and created a table that counts the number of block instances in a drawing and is able to update it via field with a diesel expression.
I also have the need to apply the solution to a file that has multiple XREFs in it.
I would like my table to have fields with sum of amount of instances of blocks across all those XREFs.
Your solution of opening each XREF is not a good fit for me since I'd like to get a sum. (And not sum it up manually).
Any ideas on LISP modification?
Message 32 of 40
prousseauCQJ6U
Hi Yael,
AutoCAD 2022 now has this feature built-in, you should look into it!
Message 33 of 40
yael.vsh
Hi
Wow, cool, thanks so much!
Unfortunately my workplace works with 2013 😑
Message 34 of 40
maxim_k
Hi @prousseauCQJ6U ,
Not AutoCAD for Mac. Only PC version has this new feature.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 35 of 40
yael.vsh
I have regular Autocad. Happened to reply in this thread because this was the topic I was looking for 🙂
But still 2013.
Message 36 of 40
akhtar4223
Hi Maxim,
The RECOUNT lsp is working very fine for me, thanks for the same.
Please refer attached drawing in which i am using RECOUNT. I have a table on layout space which shows the total count of block in Quantity column.
My request is that can i get the total count value in text where i have currently mentioned "--"
Message 37 of 40
maxim_k
Hi @akhtar4223 ,
You have to place FIELDs with DIESEL expressions instead of MTEXT in these columns.
Plus you need to modify Recount lsp so that it contains the names of all the blocks you want to count and assign these names to separate environment variables which are read by the Diesel expressions in the FIELDs.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 38 of 40
akhtar4223
Thank you very much...added expression so now it works as i want.
Message 39 of 40
akhtar4223
Hi Maxim,
I have dynamic blocks in my drawing. RECOUNT is not counting those blocks. I have attached my drawing and the LSP. Request you to help on the same.
Block with name "LC" has visibility and block with name "LL" has dynamic parameter.
Message 40 of 40
maxim_k
Hi Akhtar,
As I wrote before: this LISP doesn't support Dynamic blocks.
And because AutoCAD for Mac doesn't support Visual lisp functions the code for counting Dynamic blocks in "vanilla LISP" would be very complex.
I believe it is possible to add such code based on, for example, these code examples:
http://www.lee-mac.com/effectivename.html
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
