Mleader to Block
Mleader to Block
bit_Cad2018
Mleader to Block
bit_Cad2018
Hi Users,
                 I have lots of Mleder CS Number wise I am trying to make a block CS Number wise If you have any suggestion please tell me
Please see attached DWG file for your reference
kajanthangavel
Hi, Something for you.
Working Sample
Code Here..
Try with 'MTB'
(vl-load-com)
(defun c:mtb (/ hnd urpt str msp msp)
(defun rh:d2r (d) (* pi (/ d 180.0)))
    (if (setq ss (ssget ":L" '((0 . "MULTILEADER"))))
        (progn
            (repeat (setq i (sslength ss))
                (setq hnd (ssname ss (setq i (1- i)))
					  str (vlax-get-property (vlax-ename->vla-object hnd) 'TextString)
					  msp (cdr (assoc 110 (entget hnd)))
					  mep (cdr (assoc 10 (entget hnd)))
				(vla-getboundingbox (vlax-ename->vla-object hnd) 'mn 'mx)
                (setq urpt (vlax-safearray->list mx))
				(command "_.rotate" ss "" msp "_reference" mep msp (polar msp (rh:d2r 180) 1000))
				(if (not (tblsearch "BLOCK" (substr str 29 6)))
					(progn
						(command "_.-block" (substr str 29 6) urpt ss "" )
						(command "_.-insert" (substr str 29 6) urpt "" "" ""))
					(prompt "This Nme of Multileader already done")
(princ)
I tired with finding Multileader Base point..
I hope, It is Help to you.
Lips file here
