Multiple Mleader to Make separate Bloks
bit_Cad2018
bit_Cad2018
Hi Users
                 I have lots of Mleder CS Number wise I am trying to make a block CS Number wise If you have any suggestion please tell me
Please see attached DWG file for your reference
bit_Cad2018
I don't have received confirmation about the request posted, hence Three-time the same post posted.
sorry for that
ВeekeeCZ
Don't worry, the site is screwed. Again.
If that happen hit the Report button and ask for the removal.
ВeekeeCZ
This should make it happen.
(vl-load-com)
(defun c:MleaderBlockify (/ s i e p r n x m)
  (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    p (cdadr (member '(304 . "LEADER_LINE{") (entget e)))
	    r (getpropertyvalue e "MText/Rotation")
	    n (getpropertyvalue e "MText/Contents"))
      (if (vl-string-position (ascii ";") n nil T)
	(setq n (vl-string-right-trim "}" (substr n (+ 2 (vl-string-position (ascii ";") n nil T))))))
      (setq x -1)
      (if (tblsearch "block" n)
	(while (tblsearch "block" (setq m (strcat n "-" (itoa (setq x (1+ x))))))))
      (setq n (cond (m) (n)))
      (command "_.rotate" e "" "_non" p "_r" (angtos r (getvar 'aunits) 8) 0
	       "_.block" n "_non" p e ""
	       "_.insert" n "_s" 1 "_r" 0 "_non" p)))
  (princ)
bit_Cad2018
Dear @ВeekeeCZ thank you very much. I am grateful to you.
bit_Cad2018
okay, I will try
