division in lisp
division in lisp
GeryKnee
division in lisp
GeryKnee
There is an error here :
(defun c:xxx(/)
(setq Scale (getInt "\scale : "))
(setvar "celtscale" (/ Scale 1000) )
(princ)
error: AutoCAD variable setting rejected: "celtscale" 0
Gery.
ВeekeeCZ
(setvar "celtscale" (/ Scale 1000.0))
zero because integer divided by an integer is an integer.
You need to hah at least one real to make a result a real number. So use 1000.0 or simply 1000. (with dot at the end)
GeryKnee
OK
Thank you very much Sir,
Gery.
Sea-Haven
You have to be careful about Real and integers, when in doubt as suggested use a "."
(/ 1 3)
0
(/ 1 3.)
0.3333333
(/ 3 2)
1
(/ 3. 2.)
1.5
(* 2 pi)
(* pi 2)
6.28318530717959 note as PI is a real
GeryKnee
Thank you Sea.heaven,
I think that
(/ 3. 2.) and
(/ 3. 2)
have the same result = 1.5
regards,
Gery
hak_vz
You have
(defun c:xxx(/)
(princ)
Instead of getint use getreal
(defun c:xxx(/)
(setvar "celtscale" (/ (getreal "\nScale : ") 1000) )
(princ)
In most situation we work with real numbers.
Miljenko Hatlak
