lisp syntax
lisp syntax
GeryKnee
Message 1 of 9
lisp syntax
GeryKnee
where is the fault in following ???
(defun fnNotify (aMessage)
(princ (strcat "\n" aMessage))
(princ "\n" )
(princ)
(defun xx ()
(setq Temp (getvar "USERS1")) ;; get the double stored in "USERS1"
(fnNotify (rtos 0.001 (Temp)))
(princ)
Replies (8)
Message 2 of 9
ВeekeeCZ
What the USERS1 stores? A unit or a number as string?
(rtos 0.001 HereHasToBeAnInteger)
Also it should be (rtos 0.001 Temp), but integer-temp
Message 3 of 9
GeryKnee
Hello Sir,
take a look at this :::
(princ "\n" )
(princ)
(defun xx ()
(setvar "USERI1" 10)
(setq Temp (getvar "USERI1"))
(fnNotify (itos Temp));; itos??? a routine converting integer to string
(princ)
Gery
Message 4 of 9
ВeekeeCZ
ItoA is the function you need.
No other issue.
Message 5 of 9
ВeekeeCZ
You might also add (vl-print-to-string data) which converts any data type to string.
  (princ (strcat "\n" (vl-princ-to-string aMessage)))
  (princ "\n" )
  (princ)
(defun xx ()
  (setvar "USERS1" "10")
  (fnNotify (getvar "USERS1"))
  (princ)
(defun xx1 ()
  (fnNotify (getvar "USERI1"))
  (princ)
Message 6 of 9
GeryKnee
Thank you very much,
Gery
Message 7 of 9
GeryKnee
Plese Sir,
trying the following simple code
(princ "\n" )
(princ)
(defun c:xxx()
(fnNotify ("1"))
(princ)
I get the answer
erroc, bad function "1"
what happens???
Message 8 of 9
Moshe-A
@GeryKnee ,
First of all
(getvar "userS1") return   a string                  (same as  userS1-userS5)
(getvar "userR1") return   a real number       (same as userR1-userR5)
(getvar "userI1")  return an integer number (same as  userI1-userI5)
Second (fnNotify ("1"))
in lisp format the first item inside list (in parentheses) should be a function name
cause "1" is not, you get bad function.
it should be
(fnNotify "1")
Moshe
Message 9 of 9
john.uhden
@ВeekeeCZ
Good work, sir.  You are being quite helpful today.
John F. Uhden
