macro help needed
macro help needed
9009676
Message 1 of 9
macro help needed
9009676
when stretching a dimline there is an option if you hover above the text node for 'move text only' is there a way to write that option into a macro? something like:
^c^c_.stretch move text only /@100,100; ?
Replies (8)
Message 2 of 9
tramber
^c^c_.Rectangle \@100,100;
Should work better 😉
Message 3 of 9
9009676
thank you it worked! what doed the @ stand for / do? i think im able to optimize my workflow thanks to you! 🙂
Message 4 of 9
tramber
You must use the dynamic inputs. So that you don'y know that a point relative to the last one needs a @
Old users like me have a DYNMODE variable set to 0.
And we use @
Message 5 of 9
9009676
ah yes thank you! one other qeustion is there a way to (for example) put the option 'move text only' into a macro?
Message 6 of 9
ВeekeeCZ
Just click on the label-grip with the mouse left button and hit CTRL once or twice.
Message 7 of 9
9009676
ill need to do that 100+ times a day so thats why i'd like it if it were possible to put that option into a macro...
Message 8 of 9
ВeekeeCZ
Well, that's not so easy. It's bounded with that grip. The potential macro will just change the property but it does not activate the label movement.
Rather select all dims that you need to adjust and change the property in the Properties palette. Or do that in Dimstyle for all new dims. Then you can move the label right away just by grabbing the grip.
Message 9 of 9
jreidKVSUZ
You can use QSELECT. Pick MTEXT or TEXT. Say OK.
Then type Move and then your distance 100,100
Hope this helps.
JRR!
