when stretching a dimline there is an option if you hover above the text node for 'move text only' is there a way to write that option into a macro? something like:
^c^c_.stretch move text only /@100,100; ?
You must use the dynamic inputs. So that you don'y know that a point relative to the last one needs a @
Old users like me have a DYNMODE variable set to 0.
And we use @
ah yes thank you! one other qeustion is there a way to (for example) put the option 'move text only' into a macro?
ill need to do that 100+ times a day so thats why i'd like it if it were possible to put that option into a macro...
Well, that's not so easy. It's bounded with that grip. The potential macro will just change the property but it does not activate the label movement.
Rather select all dims that you need to adjust and change the property in the Properties palette. Or do that in Dimstyle for all new dims. Then you can move the label right away just by grabbing the grip.
