matchprop from line/pline on xref
sunlight1
Message 1 of 8
sunlight1
hi all,
i need a lisp that can change the layers prop of an xref lines that i want,
i dont need to change them in the original xref file,
only to change them on my file to match my ctb file.
i want that the xref lines (that i pick) take all my line prop, color,linetype, lineweight xtc
im using a lisp that change the color of xref line. so i thought why whouldn"t i find a lisp that can change more than a color.
my plan is to set my own legend and start converting lines from an xref
Replies (7)
Message 2 of 8
pbejse
Where is the lisp code? Mind posting it here.
Message 3 of 8
sunlight1
i think i found it here, cant find the post ATM
this is not matchprop so i thought ist not relevant
(defun c:clc (/ c d e l)
;; RJP » 2018-08-17
;; Set layer color by pick
(or (getenv "clc") (setenv "clc" "(62 . 1)"))
(cond ((setq c (acad_truecolordlg (read (getenv "clc"))))
(setenv "clc" (vl-prin1-to-string (last c)))
(setq d (vla-get-activedocument (vlax-get-acad-object)))
(while (and (setq e (car (nentsel "\nSelect entity to change layer color: ")))
(setq l (tblobjname "layer" (cdr (assoc 8 (entget e)))))
(entmod (append (entget l) c))
(vla-regen d acactiveviewport)
(princ)
(vl-load-com)
Message 4 of 8
pbejse
;; RJP » 2018-08-17 ;; Set layer color by pick
I know that guy, he'll come along and get you sorted.
Message 5 of 8
Kent1Cooper
i think i found it here....
That is not to change the color of the selected object, but of the Layer it's on.  If you really have something that will change the color of a nested selected object, it should be adjustable to change other properties, but I'm having a hard time imagining how that could be done, without changing it in the source Xref.
Kent Cooper, AIA
Message 6 of 8
sunlight1
i dont need to change the layer in the source Xref,
i only need to change the properties in the LAYER PROPERTIES MANAGER in the main file.
which get me the properties of a line, and copy them to the LAYER PROPERTIES MANAGER of an xref layer i choose.
it should looks like this
pick a line/pl
get the prop
pick an xref line
then copy the line prop (u've got) to that xref layer in the LAYER PROPERTIES MANAGER (of the main file)
that whould change the layer.
thats it.
Message 7 of 8
Kent1Cooper
This from Message 1 is what sounded like you were talking about changing the properties of an object, not of its Layer:
"im using a lisp that change the color of xref line."
Also, you say "this is not matchprop so i thought ist not relevant".  MATCHPROP can't be relevant to changing a Layer's properties, anyway -- it is only about the properties of objects.
Do you just want to modify the code you posted from asking the User for a color to getting the color from an object, and add more properties to be changed?
If the color/linetype/lineweight/transparency of the first-selected object is BYLAYER, do I assume correctly that you would want that property of its Layer extracted and given to the Xref Layer?  [BYLAYER cannot be assigned to a Layer's properties.]
Kent Cooper, AIA
Message 8 of 8
sunlight1
ok, im sorry if u misunderstood me.
the only reason i posterd the lisp, is that pbejse ask for it.
in that lisp i posted (i didnt wrote it like u know)
u choose the color u want the layer change.
this is not good for my post because i dont want to choose color, i want that the list COPY the prop from a line i choose, exactly like Matchprop command does.
the good thing for my post about the lisp i posted is that color layer i choose, is changing in the right place i need here, in the LAYER PROPERTIES MANAGER.
im sorry of i misnderstood,
i need layer change, not object.
my goal is to have template that contains my layers and lines,
and then easily change xref layers to my layers line with the same properties
