List Manuipulation
List Manuipulation
Moshe-A
Mentor Mentor
Message 1 of 12
List Manuipulation
Moshe-A
and i have another issue
have the list (setq selected^ '(0 5 9 12 18))
and have list of strings (setq layouts^ '("sheet a0" "sheet a1" "sheet a2"))
i looking for the most efficient way to turn it => "sheet a0,sheet a1, sheet a2"
what i tried is this:
(defun concat (item)
 (strcat (nth item layouts^) ",")
(apply 'concat selected^)
and i'm getting this error
error: too many arguments
why this will work => (apply '+ selected^) returns 44
but my defined concat does not? what's the different?
again looking for the most efficient way to do it.
thanks
Moshe
Replies (11)
Message 2 of 12
pbejse
Depending on what or how you are planning to use the result
(substr (apply 'strcat
	       (mapcar '(lambda (a)
		   (strcat "," a)) layouts^)) 2)
"sheet a0,sheet a1,sheet a2"
 What does the value for selected^  referencing to?
'(0 5 9 12 18)
How is it related to layouts^ variable?
Message 3 of 12
Moshe-A
the selected^ list are the selected list_box items from the previous thread
Message 4 of 12
Moshe-A
i sorry my mistake
lets' say the selected is:
(setq selected^ '(0 2 4))
and layouts:
(setq layouts '("sheet a0" "sheet a1" "sheet a2" "sheet a3" "sheet a4"))
the result should be:  "sheet a0,sheet a2,sheet a4"
Message 5 of 12
pbejse
@Moshe-A wrote:
..why this will work => (apply '+ selected^) returns 44
	0 + 5 + 9 +  12 + 18
while
"sheet a0"
	(strcat
	  	(nth "sheet a0" layouts^) ",")
"sheet a1" (strcat (nth "sheet a1" layouts^) ",") "sheet a2" (strcat (nth "sheet a2" layouts^) ",")
Which will crash because function nth is expecting an integer.
(defun concat (item) (strcat item ","))
(mapcar 'concat layouts^)
will give you
("sheet a0," "sheet a1," "sheet a2,")
then
(apply 'strcat '("sheet a0," "sheet a1," "sheet a2,"))
will give you
"sheet a0,sheet a1,sheet a2,"
Message 6 of 12
Moshe-A
OK figure it out
(substr  (apply  'strcat (mapcar '(lambda (item) (strcat "," (nth item layouts^))) selected^)) 2)
thanks mate
Message 7 of 12
pbejse
FWIW: For  your original code
	(strcat "," (nth item layouts) )
	       (mapcar 'concat
				(read (Strcat "(" selected^ ")")))
	2
Message 8 of 12
Moshe-A
pbejse,
that ok but i was refering to apply function, i seems to me that apply function accepts only a build-in autolisp functions not a custom by defun (although it's wrriten in the document)  am i right?
Signature
(apply 'function list)
'function
Type: Symbol
A function.
The function argument can be either a symbol identifying a defun, or a lambda expression.
list
Type: List or nil
A list.
If the function accepts no arguments, the value can be nil.
Message 9 of 12
pbejse
Not really, depending on how you use the function
(Defun concat (lst)
    	(mapcar '(lambda  (n)
		   (Strcat "," (nth n lst)) ) selected^)
(substr
(apply 'strcat
(apply 'concat (list layouts))
2
Which is an odd way of concatenating the strings
Message 10 of 12
Moshe-A
and what this means from 'apply point of view'...if you use a defun symbol then the list argument can be a list with only 1 item in?!
that the meaning on doing: (apply 'concat (list layouts))
cause layouts is already a list - right?!
and this does works (apply 'strcat layouts)  - right?!
then why this won't work?
(apply 'concat layouts)
maybe other has explanation to this?
Message 11 of 12
cadffm
 >returns 44 but my defined concat does not? what's the different?
The answer is more simple than funny.
"error: too many arguments"
It is easy and you know it: A function expects X arguments and you send more or less arguments.
Your concat expects  ONE argument, but you pass  5 arguments! (five item in selected^ list)
 A fine working example:
(setq layouts^ '("sheet a0" "sheet a1" "sheet a2" "sheet a3" "sheet a4" "sheet a5"))
(defun concat (a1 a2 a3) ;; <- 3 Arguments wanted
 (strcat (nth a1 layouts^) "," (nth a2 layouts^) "," (nth a3 layouts^))
(apply 'concat selected^) ;; 3 Arguments given
Thats how apply works, it is not iterate thru a list like foreach ore mapcar.
" i seems to me that apply function accepts only a build-in autolisp functions not a custom by defun (although it's wrriten in the document)  am i right?"
No .
Apply works like all other your own function!
Apply is not the problem, the difference is between functions like + - strcat ... and your own functions.
The difference is: This functions allows a dynamic length of argument list!
You are (with lisp) not able to define a function which allows a dynamic length of arguments.
So Apply is useless for using own functions within.
Sebastian
Message 12 of 12
Moshe-A
Ok Sebastian
now it is clear
it's pity the documentation fail to explain it this way
