vla-open \ vla-close \ copy table objects
Moshe-A
Mentor Mentor
Moshe-A
ok today is my day  Smiley LOL
i  open another database (a dwt or a dwg):
(setq dbx (vlax-create-object (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'acadver) 1 2))))
(vla-open dbx "MyTemp.dwt")
(vl-open) returns nil instead of document object
but i looks like the dbx object is a document object but does not have a close method
so how can i close the file?
i want to copy some tables object like layers, linetypes and textstyles from "MyTemp.dwt" to the current document.
the (vla-copy) is coping to the same location - not suit
the (vla-copyFrom) handles only dimension style, layout, or plot configuration - not suit
and the (vla-copyObjects) deals with Graphics objects - not suit
so can i copy table records?
Moshe
_gile
You can use CopyObjects to copy non-graphical objects, you just have to specify the right source objects with the according target owner (table or dictionary).
To 'close' the file, use the vlax-release-object function.
Here's a little sample
(vl-load-com)
(or *acad* (setq *acad* (vlax-get-acad-object)))
(or *acdoc* (setq *acdoc* (vla-get-ActiveDocument *acad*)))
(or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)))
(or *layers* (setq *layers* (vla-get-Layers *acdoc*)))
(defun gc:GetAxDbDoc (filename / majVer progId axdbdoc)
  (vl-load-com)
  (setq progId
         (if (< (setq majVer (substr (getvar 'acadver) 1 2)) "16")
           "ObjectDBX.AxDbDocument"
           (strcat "ObjectDBX.AxDbDocument." majVer)
  (if (setq axdbdoc (vlax-create-object progId))
    (if (vl-catch-all-apply
          'vla-open
          (list axdbdoc filename)
      (not (vlax-release-object axdbdoc))
      axdbdoc
((lambda (/ doc)
   (if (setq doc (gc:GetAxDbDoc "MyTemp.dwt"))
     (progn
       (vlax-invoke doc 'CopyObjects (list (vla-Item (vla-get-Layers doc) "LayerName") ) *layers* )
       (vlax-invoke doc 'CopyObjects (list (vla-Item (vla-get-Blocks doc) "BlockName") ) *blocks* )
       (vlax-release-object doc)
Gilles Chanteau
GileCAD
GitHub
Moshe-A
Gilles,
thanks  alot...yes i have figured it that (vla-copyObject) is the function to do it.
but how do you explain that (vla-open) returns nil? and the documentation says it should return a  document object.
overall that, how do you explain the big gap between the documentation and how the function is actually works.
here is the the documentation for copyObjects, as you can see the arguments should be variants?!
when autodesk will fix this?!
thanks again,
Moshe
VBA:
RetVal = object.CopyObjects(Objects [, Owner] [, IDPairs])
object
Type: Database, Document
The objects this method applies to.
Objects
Access: Input-only
Type: Variant (array of Objects)
The array of primary objects to be copied. All the objects must have the same owner, and the owner must belong to the database or document that is calling this method.
Owner
Access: Input-only; optional
Type: Variant (a single object)
The new owner for the copied objects. If no owner is specified, the objects will be created with the same owner as the objects in the Objects array.
IDPairs
Access: Input-output; optional
Type: Variant (array of IDPair objects)
Information on what happened during the copy and translation process.
  • Input: an empty variant.
  • Output: an array of IDPair objects.
Return Value (RetVal)
Type: Variant (array of objects)
An array of newly created duplicate objects. Only primary objects are returned in this array. For more information on what occurred during the CopyObjects operation, or a list of objects owned by primary objects that were also copied, consult the IDPairs parameter.
_gile
You should insure "MyTemp.dwt" is a valid file name.
(if (setq filename (findfile "MyTemp.dwt"))
  (progn
    (vla-open dbx filename)
Using the 'old style' (vlax-invoke object method ...) is a work around to avoid the variant stuff.
(vlax-invoke doc 'CopyObjects (list (vla-Item (vla-get-Layers doc) "LayerName")) *layers*)
Works the same as:
(vla-CopyObjects
  doc
  (vlax-make-variant
    (vlax-safearray-fill
      (vlax-make-safearray
        vlax-vbObject
        '(0 . 0)
  *layers*
Gilles Chanteau
GileCAD
GitHub
