from string to list
from string to list
Moshe-A
Mentor Mentor
from string to list
Moshe-A
Guys hi,
i looking for the most efficient way (a function) to convert a string to list. the string is coming from a dcl list_box.
from this: "0 5 9 12 18"
to this:      '(0 5 9 12 18)
thanks
Moshe
pbejse
(read (Strcat "("  "0 5 9 12 18" ")"))
(Setq info  "0 5 9 12 18" ")
(read (Strcat "("  info ")"))
Moshe-A
thanks pbejse
Excellent  Smiley LOL
john.uhden
That's great for space-delimited strings.
What about comma or tab-delimited strings, or multicharacter delimited strings?
I use this:
  ;; Function to convert a string with delimiters into a list
  ;; pat is the delimiter and can contain multiple characters
  (defun @str2list (str pat / i j n lst)
     (cond
        ((/= (type str)(type pat) 'STR))
        ((= str pat)'(""))
        (T
           (setq i 0 n (strlen pat))
           (while (setq j (vl-string-search pat str i))
             (setq lst (cons (substr str (1+ i)(- j i)) lst)
                   i (+ j n)
           (reverse (cons (substr str (1+ i)) lst))
Command: (setq str "1<>2<>5<>9<>12<>18")
Command: (@str2list str "<>")
("1" "2" "5" "9" "12" "18")
John F. Uhden
pbejse
The request is for specifically converting the value from DCL list box with multiple selection options.
The format will always be similar to this--> "0 5 9 12 18"  "2 4 10"
Say, what about, converting the string value depending on what type it is.
"0 5 9 12 Apple Banana 12.34 Man"  --> (0 5 9 12 "Apple" "Banana" 12.34 "Man")
pbejse
To make it more interesting
"0 5 9 12 Apple Banana 12.34 Man (1.0 2.0 0.0) (2.0 4.0 0.0)"
to
(list 0 5 9 12 "Apple" "Banana" 12.34 "Man" '(1.0 2.0 0.0) '(2.0 4.0 0.0))
john.uhden
Very interesting, if there were a use for it.
My apologies for missing the DCL usage.  I guess I had better check out what I have ever done with multi-select list boxes.  Your solution looks perfect.
John F. Uhden
