List Manipulation
List Manipulation
avinash00002002
Message 1 of 15
List Manipulation
avinash00002002
Hi!
I have some lists one of them I am putting here for help.
original
(25 299.4 100.3 100.8 399.3 118.9 25)
convert to 0.5  precision
(25.0 299.5 100.5 101.0 399.5 119.0 25.0)
I want to convert to 0.5 but the total of all members in a list is 1069.5 but I need to convert in 1070.
final summation of list members shall be 0.0 not .5
avinash
Replies (14)
Message 2 of 15
ВeekeeCZ
So add 0.5 to the first or last 25. That way, you'll the minimum overall error.
However, without more context, why 1070, it's a bit of a guess...
Message 3 of 15
komondormrex
hey,
check the following
(defun round_0_5 (number)
	(if (< (rem number 1) 0.5)
	  (float (+ (fix number) 0.5))
	  (fix (+ 0.5 number))
(fix (+ 0.5 (apply '+ (mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25))))) ->1071
Message 4 of 15
Moshe-A
@avinash00002002  hi,
check this function, it will convert numbers to 0.5
i leave the sum up for you and convert it to integer with (rtos)
enjoy,
Moshe
(defun prec05 (lst / b)
  (mapcar
   '(lambda (n)
     (setq b (rem n 1))
     (cond
      ((= b 0.0) (atof (rtos n 2 1)))
      ((< b 0.29999)
       (atof (rtos (fix n) 2 1))
      ((< b 0.69999)
       (+ (fix n) 0.5)
      ( t
       (atof (rtos (+ (fix n) 1) 2 1))
     ); cond
    ); lambda
   lst
Message 5 of 15
avinash00002002
Thtanks for prompt reply,
I need +0.5/-0.5 in list members also after sumation of list member required rounding number
Message 6 of 15
avinash00002002
HI!
I need summation of list members in rouning 0 to next + member like 1069.5 to 1070.
needs to be adjust 0.5 to somewhere where in member which has max. of decimal value
Message 7 of 15
Moshe-A
@avinash00002002 ,
how about this?
  (atoi
    (rtos
      (apply
       (mapcar
         '(lambda (n)
           (setq b (rem n 1))
           (cond
            ((< b 0.29999)
            ((< b 0.69999)
             (+ (fix n) 0.5)
            ( t
           ); cond
          ); lambda
         lst
       ); mapcar
      ); apply
      2 0
    ); rtos
  ); atoi
Message 8 of 15
avinash00002002
Hi!
thanks for your prompt reply,
1. I need total of list members are to be rounded value like 1070
2. I need also change the list member value also to get the value of 1070.
Message 9 of 15
Moshe-A
@avinash00002002 ,
from your replay i conclude that you did not run (prec05) function - why?!
this is what i get when i run it:
(prec05 '(25 299.4 100.3 100.8 399.3 118.9 25)) return 1070
Message 10 of 15
avinash00002002
Thanks for your reply,
I ran your function, I need to change in list members value also, I need invidudial members value also.
is it possible?
Message 11 of 15
komondormrex
@avinash00002002
1. updated
2. updated for negative having numbers in list
3. updated for negative sum
(defun round_0_5 (number / sign)
  (setq sign (/ number (abs number))
	number (abs number)
  (cond
    ((zerop (rem number 1)) (* sign (float number)))
    ((< (rem number 1) 0.5) (* sign (float (+ (fix number) 0.5))))
    (t (* sign (float (fix (+ 0.5 number)))))
(defun round_up (number / sign)
	number (abs number)
	number (* sign (fix (+ 0.5 number)))
(mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25)) -> (25.0 299.5 100.5 101.0 399.5 119.0 25.0)
(round_up (apply '+ (mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25)))))-> 1070.0
Message 12 of 15
Moshe-A
@avinash00002002
i split it to two functions:
first (prec05) return the list rounded 0.5
second (lst->int) return the sum of list of numbers rounded to integer.
(prec05 '(25 299.4 100.3 100.8 399.3 118.9 25)) =>=>  (25.0 299.5 100.5 101.0 399.5 119.0 25.0)
(lst->int '(25 299.4 100.3 100.8 399.3 118.9 25)) =>=> 1070
what next?  😀
 (mapcar
  '(lambda (n)
    (setq b (rem n 1))
    (cond
     ((< b 0.29999)
     ((< b 0.69999)
      (+ (fix n) 0.5)
     ( t
    ); cond
   ); lambda
   lst
 ); mapcar
(defun lst->int (lst)
 (atoi (rtos (apply '+ (prec05 lst)) 2 0))
Message 13 of 15
ВeekeeCZ
Here's my take
(defun :roundup_memb-to-0.5_sum-to-1 (lst / LM:roundup ret dif idx)
  ;; Round Up  -  Lee Mac ;; Rounds 'n' up to the nearest 'm'
  (defun LM:roundup ( n m ) ((lambda ( r ) (cond ((equal 0.0 r 1e-8) n) ((< n 0) (- n r)) ((+ n (- m r))))) (rem n m)))
  (setq lst (mapcar 'float lst)
	ret (mapcar '(lambda (x) (LM:roundup x 0.5)) lst))
  (if (> (LM:roundup (apply '+ ret) 1.) (apply '+ ret))
    (setq dif (mapcar '- ret lst)
	  pos (vl-position (apply 'min dif) dif)
	  idx -1
	  ret (mapcar '(lambda (x) (if (= pos (setq idx (1+ idx))) (+ x 0.5) x)) ret))
    ret))
;>> (:roundup_memb-to-0.5_sum-to-1 '(25 299.4 100.3 100.8 399.3 118.9 25))
;>> (25.5 299.5 100.5 101.0 399.5 119.0 25.0)
Message 14 of 15
avinash00002002
Thanks for your prompt reply,
summation of list is 1068.7
 I need the sumation of list next roundup is 1069.
the summation of more than 0.6 it give 1069 and less than 0.6 than 1068
Message 15 of 15
Moshe-A
@avinash00002002 ,
(atoi (rtos (apply '+ '(25 299.4 100.3 100.8 399.3 118.9 25)) 2 0)) => 1069
you started with rounding numbers to 0.5 (and now rounding is not needed?)
you been giving solutions and did not respond
it's about time you explain what is your goal here?
(use google translate so we can understand)
