List Manipulation
List Manipulation
avinash00002002
Message 1 of 14
List Manipulation
avinash00002002
Hi!
I have some lists one of them I am putting here for help.
original
(25 299.4 100.3 100.8 399.3 118.9 25)
convert to 0.5  precision
(25.0 299.5 100.5 101.0 399.5 119.0 25.0)
I want to convert to 0.5 but the total of all members in a list is 1069.5 but I need to convert in 1070.
final summation of list members shall be 0.0 not .5
avinash
Replies (13)
Message 2 of 14
ВeekeeCZ
So add 0.5 to the first or last 25. That way, you'll the minimum overall error.
However, without more context, why 1070, it's a bit of a guess...
Message 3 of 14
komondormrex
hey,
check the following
(defun round_0_5 (number)
	(if (< (rem number 1) 0.5)
	  (float (+ (fix number) 0.5))
	  (fix (+ 0.5 number))
(fix (+ 0.5 (apply '+ (mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25))))) ->1071
Message 4 of 14
Moshe-A
@avinash00002002  hi,
check this function, it will convert numbers to 0.5
i leave the sum up for you and convert it to integer with (rtos)
enjoy,
Moshe
(defun prec05 (lst / b)
  (mapcar
   '(lambda (n)
     (setq b (rem n 1))
     (cond
      ((= b 0.0) (atof (rtos n 2 1)))
      ((< b 0.29999)
       (atof (rtos (fix n) 2 1))
      ((< b 0.69999)
       (+ (fix n) 0.5)
      ( t
       (atof (rtos (+ (fix n) 1) 2 1))
     ); cond
    ); lambda
   lst
Message 5 of 14
avinash00002002
Thtanks for prompt reply,
I need +0.5/-0.5 in list members also after sumation of list member required rounding number
Message 6 of 14
avinash00002002
HI!
I need summation of list members in rouning 0 to next + member like 1069.5 to 1070.
needs to be adjust 0.5 to somewhere where in member which has max. of decimal value
Message 7 of 14
Moshe-A
@avinash00002002 ,
how about this?
  (atoi
    (rtos
      (apply
       (mapcar
         '(lambda (n)
           (setq b (rem n 1))
           (cond
            ((< b 0.29999)
            ((< b 0.69999)
             (+ (fix n) 0.5)
            ( t
           ); cond
          ); lambda
         lst
       ); mapcar
      ); apply
      2 0
    ); rtos
  ); atoi
Message 8 of 14
avinash00002002
Hi!
thanks for your prompt reply,
1. I need total of list members are to be rounded value like 1070
2. I need also change the list member value also to get the value of 1070.
Message 9 of 14
Moshe-A
@avinash00002002 ,
from your replay i conclude that you did not run (prec05) function - why?!
this is what i get when i run it:
(prec05 '(25 299.4 100.3 100.8 399.3 118.9 25)) return 1070
Message 10 of 14
avinash00002002
Thanks for your reply,
I ran your function, I need to change in list members value also, I need invidudial members value also.
is it possible?
Message 11 of 14
komondormrex
@avinash00002002
1. updated
2. updated for negative having numbers in list
3. updated for negative sum
(defun round_0_5 (number / sign)
  (setq sign (/ number (abs number))
	number (abs number)
  (cond
    ((zerop (rem number 1)) (* sign (float number)))
    ((< (rem number 1) 0.5) (* sign (float (+ (fix number) 0.5))))
    (t (* sign (float (fix (+ 0.5 number)))))
(defun round_up (number / sign)
	number (abs number)
	number (* sign (fix (+ 0.5 number)))
(mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25)) -> (25.0 299.5 100.5 101.0 399.5 119.0 25.0)
(round_up (apply '+ (mapcar 'round_0_5 '(25 299.4 100.3 100.8 399.3 118.9 25)))))-> 1070.0
Message 12 of 14
Moshe-A
@avinash00002002
i split it to two functions:
first (prec05) return the list rounded 0.5
second (lst->int) return the sum of list of numbers rounded to integer.
(prec05 '(25 299.4 100.3 100.8 399.3 118.9 25)) =>=>  (25.0 299.5 100.5 101.0 399.5 119.0 25.0)
(lst->int '(25 299.4 100.3 100.8 399.3 118.9 25)) =>=> 1070
what next?  😀
 (mapcar
  '(lambda (n)
    (setq b (rem n 1))
    (cond
     ((< b 0.29999)
     ((< b 0.69999)
      (+ (fix n) 0.5)
     ( t
    ); cond
   ); lambda
   lst
 ); mapcar
(defun lst->int (lst)
 (atoi (rtos (apply '+ (prec05 lst)) 2 0))
Message 13 of 14
ВeekeeCZ
Here's my take
(defun :roundup_memb-to-0.5_sum-to-1 (lst / LM:roundup ret dif idx)
  ;; Round Up  -  Lee Mac ;; Rounds 'n' up to the nearest 'm'
  (defun LM:roundup ( n m ) ((lambda ( r ) (cond ((equal 0.0 r 1e-8) n) ((< n 0) (- n r)) ((+ n (- m r))))) (rem n m)))
  (setq lst (mapcar 'float lst)
	ret (mapcar '(lambda (x) (LM:roundup x 0.5)) lst))
  (if (> (LM:roundup (apply '+ ret) 1.) (apply '+ ret))
    (setq dif (mapcar '- ret lst)
	  pos (vl-position (apply 'min dif) dif)
	  idx -1
	  ret (mapcar '(lambda (x) (if (= pos (setq idx (1+ idx))) (+ x 0.5) x)) ret))
    ret))
;>> (:roundup_memb-to-0.5_sum-to-1 '(25 299.4 100.3 100.8 399.3 118.9 25))
;>> (25.5 299.5 100.5 101.0 399.5 119.0 25.0)
Message 14 of 14
avinash00002002
Thanks for your prompt reply,
summation of list is 1068.7
 I need the sumation of list next roundup is 1069.
the summation of more than 0.6 it give 1069 and less than 0.6 than 1068
