LISP request for advanced find from a list
smallƑish
Message 1 of 49
smallƑish
I have a list in a notepad file
the same data included in a dwg file as a block attribute
Just needed to find the att with the effect of  the find command
sample files attached  attached
purpose  of the process is; (nothing to do with code, just for understanding )
1. make sure I didn't miss any att
2. location of the block is an in correct room
Replies (48)
Message 2 of 49
paullimapa
What happens when you run the Find command
Are the results not what you expected
Paul Li
IT Specialist
@The Office
Message 3 of 49
smallƑish
"Find" is working properly, but if there is a bulk quantity, it's a ton of time-consuming.
Message 4 of 49
paullimapa
doesn't matter if there's a bulk and with code it'll fly by the find process.
so where's the code?
Paul Li
IT Specialist
@The Office
Message 5 of 49
smallƑish
i don't have any code 😞
Message 6 of 49
paullimapa
So explain clearly what happens when a match is found
Paul Li
IT Specialist
@The Office
Message 7 of 49
smallƑish
What I imagine is, When the code runs, let it find the first line data from the notepad, and find the match att block. Then press any key (TAB) let it jump to second line and pan to the particular att match in the dwg. Similarly till end of the line from notepad.
Message 8 of 49
smallƑish
If copy paste from Note pad data to DWG, as text or Mtext also preferable, if it may difficult to connect with Notepad file.
Message 9 of 49
paullimapa
Try FnAtV.lsp attached.
It doesn't allow you to TAB but at least you can choose from options at the command line as to how to respond when matching items are found.
Note the following settings that can be modified to your requirements at the beginning of the code:
 (setq blknam "-EP-LEEDER-1" ; block name
       lyrnam "Verified"     ; layer name
       lyrcol "3"            ; layer color
       tagnam "CIRCUIT"      ; attribute tag name
       zmfac  ".2x"          ; zoom away from object factor
Paul Li
IT Specialist
@The Office
Message 10 of 49
smallƑish
OMG it's working with a lot of advanced features. Thank you so much. It's a TON time saver.
Message 11 of 49
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Message 12 of 49
smallƑish
if possible can you just add  verified and unverified  buttons here also?
When we found duplicate blocks.
Message 13 of 49
paullimapa
ok, try this modified version.
Paul Li
IT Specialist
@The Office
Message 14 of 49
smallƑish
I apologise,My mistake, I have made a wrong post and edited Message 12.
Message 15 of 49
paullimapa
So not Verifiedall but just Verified which applies to the current highlighted item?
Clicking Next or Previous is the same as Unverified right?
Paul Li
IT Specialist
@The Office
Message 16 of 49
smallƑish
My request is having all 4 options,
1. Next / previous
2. Exit
3. Verified
4. Unverified
So we can compare previous and next, then verify the correct one/multiple, and move on.
Message 17 of 49
paullimapa
4 options are:
Next - won’t show on last item
Previous - won’t show on first item
Verified - this option changes highlighted item’s layer
Exit - this option exits out of reviewing the current matching set
What does Unverified do?
Paul Li
IT Specialist
@The Office
Message 18 of 49
smallƑish
True, sometimes I do overthinking 😭
Message 19 of 49
paullimapa
try this version
Paul Li
IT Specialist
@The Office
Message 20 of 49
smallƑish
Yes. Yes
This version 100% suite with the requirements
It's hard to believe your patience level. 🫡
Thank you so much Sir
