For faster workflow, can help me to write a code that enables selecting an object and adjusting its draw order to bring it to the front."
Solved by komondormrex. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
I've used the attached DraworderBackFront.lsp with its DB command to put things at the Back, and DF to put them at the Front. Single or multiple object(s), including noun-verb operation [pre-selection]. Also posted before, >here< -- see Message 6 there for (autoload) to have it available but not loaded until called for.
(vl-cmdf "_.draworder" (car (entsel "\nPick entity to move to front: ")) "" "_f")
You could also try to access from display order Toolbar
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-510E8CAF-3B78-4890-BE2E-0740E98ACBC8
