I accidentally posted this in the installation and licensing forum (I have no idea why I was there rather than here)
I've got next to zero experience using LISPs, but I managed to find one that would add up the total length of selected objects. The output is an alert displaying the total length. I've been asked to try and find a way to change this so it is displayed as text, or in a table.
I'm currently drawing duct plans, and I'm using the lisp to find the total length of ducting required. What would be great is if I could use the lisp multiple times, and each value is added to a table, adding a new row for each type of ducting. Is this possible to achieve? If the output was text, then I could place that into a table manually.
I'm currently using this lisp http://www.turvill.com/t2/free_stuff/tlen.lsp
Finally, where's the best place for a total novice to learn how to write a lisp. I've been looking around using google, but you might know of some hidden gems. I've been recommended Afralisp, which I've already started looking at.
