Center line for circles,slots etc.
Hi everyone,
I wonder if you could help me with this lisp , it will save me a lot of time:
http://www.imagehost.co.il/view.php?filename=252017_04_04_10_01_19.jpg
first I want to pick a polyline ( it can be a CIRCLE , SLOT ,RECTANGLE , with any angle) ,
then it will ask for line extension dimension ( for example 5mm , as shown in the picture attached)
and it will make a center lines with the extension as specified , the center line should be as shown in the pic , dashed dot , and layer named "center line"
color red.
It's important that program will identify the position , means that if the rectangle or the slot is with angle ( like shown in the pic) it will draw the center line aligned.
Thank you very much in advance.
dennis
You could upgrade to AutoCAD 2018: New Feature Center Mark and Centerlines
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
Kent1Cooper
color red.
Give this a try.  It doesn't yet have *error* handling, or suppress command echoing, or save the current Layer first and restore it later, or deal with different Coordinate Systems, etc., etc., but it seems to work.
(defun C:CLM ; = Center Line Marks
  (/ ss n ent edata pt1 ctr rad pt2 pt3 pt4)
  (command "_.layer" "_make" "CENTER LINE" "_color" "1" "" "_ltype" "DASHDOT" "" "")
  (if
    (setq ss
      (ssget
          (-4 . "<OR")
            (0 . "CIRCLE")
            (-4 . "<AND")
              (0 . "LWPOLYLINE")
              (90 . 4); 4 vertices
              (-4 . "&") (70 . 1); closed
            (-4 . "AND>")
          (-4 . "OR>")
      ); ssget
    ); setq
    (progn ; then
      (setq *CLMext*
        (cond
          ( (getdist
              (strcat
                "\nLength of Center Line extensions past perimeter <"
                (rtos (cond (*CLMext*) (5))); in current Units mode/precision
              ); strcat
            ); getdist
          ); User-input condition
          (*CLMext*); on Enter with prior value
          (5); on Enter without prior value [first use]
        ); cond
      ); setq
      (repeat (setq n (sslength ss))
        (setq ent (ssname ss (setq n (1- n))))
        (if (= (cdr (assoc 0 (setq edata (entget ent)))) "CIRCLE")
          (setq ; then
            pt1 (polar (setq ctr (cdr (assoc 10 edata))) 0 (setq rad (cdr (assoc 40 edata))))
            pt2 (polar ctr (/ pi 2) rad)
            pt3 (polar ctr pi rad)
            pt4 (polar ctr (* pi 1.5) rad)
          ); setq
          (setq ; else -- LWPolyline
            pt1 (vlax-curve-getPointAtParam ent 0.5)
            pt2 (vlax-curve-getPointAtParam ent 1.5)
            pt3 (vlax-curve-getPointAtParam ent 2.5)
            pt4 (vlax-curve-getPointAtParam ent 3.5)
          ); setq
        ); if
        (command
          "_.line"
          "_none" (polar pt1 (angle pt3 pt1) *CLMext*)
          "_none" (polar pt3 (angle pt1 pt3) *CLMext*)
          "_.line"
          "_none" (polar pt2 (angle pt4 pt2) *CLMext*)
          "_none" (polar pt4 (angle pt2 pt4) *CLMext*)
        ); command
      ); repeat
    ); progn
  ); if
  (princ)
); defun
NOTE that it filters only for Circles and closed 4-segment Polylines.  In the case of the latter, it will work with any like that -- it does not evaluate whether they are slot- or rectangle-shaped, but draws the Lines across the midpoints of the 4 segments, however they may be arranged, as in the right side of the image.  It could be made to check for that kind of thing, if desired.
Kent Cooper, AIA
pbejse
Nice
WoW !! Kent Cooper,
You're great!
thank you very very much this lisp will save me a lot of time.
Eyal.
