Lisp help
Lisp help
Message 1 of 17
Lisp help
I accidentally posted this in the installation and licensing forum (I have no idea why I was there rather than here)
I've got next to zero experience using LISPs, but I managed to find one that would add up the total length of selected objects. The output is an alert displaying the total length. I've been asked to try and find a way to change this so it is displayed as text, or in a table.
I'm currently drawing duct plans, and I'm using the lisp to find the total length of ducting required. What would be great is if I could use the lisp multiple times, and each value is added to a table, adding a new row for each type of ducting. Is this possible to achieve? If the output was text, then I could place that into a table manually.
I'm currently using this lisp http://www.turvill.com/t2/free_stuff/tlen.lsp
Finally, where's the best place for a total novice to learn how to write a lisp. I've been looking around using google, but you might know of some hidden gems. I've been recommended Afralisp, which I've already started looking at.
Replies (16)
Message 2 of 17
Slawomir_
it seems that solution for your task is already in plain AutoCAD. Try DATAEXTRACTION wizard. I have used it often for several different kind of tasks and it did a great job. For Your purpose it should work great.
By the way good AutoLISP site is here.
Message 3 of 17
cadwomen
Hy
so take a look there , hope i am right
http://www.lee-mac.com/lengthfieldtoattribute.html
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Message 4 of 17
cadwomen
or more like this ?
http://www.lee-mac.com/chainlength.html
cu cw
Message 5 of 17
hencoop
More good lisp learning sites: TheSwamp; CADTutor
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Message 6 of 17
I've had a look at the DATAEXTRACTON wizard, and it does help, but it shows too much information. Is it possible to tell it to show just a select few layers? I've got a lot going on in some of my drawings, and I get hundreds of lines of information, when I really only need between 4-8.
Thanks everyone for your suggestions for LISP sites 🙂
Message 7 of 17
ВeekeeCZ
Isolate desired layers and use DE on the selection.
Message 8 of 17
Slawomir_
Hi, have you solved your problem?
Message 9 of 17
Not really. I'm getting closer though.
Message 10 of 17
This only partially worked. I have 241 polylines on 12 layers. What I need is to be able to show the total length of the polylines on each layer, so I should end up with a table of 12 lines.
I have isolated the 12 layers, then used DATAEXTRACTION, but it still gives me results for other layers. The more I'm looking into this, the more I'm thinking if what I'm trying to achieve is actually possible.
Message 11 of 17
ВeekeeCZ
Layer Isolation only helps you to select desired objects - you still need to select those objects manually - Page 2 of DE
Message 12 of 17
hmsilva
Hi jcolesRA725,
try this @alanjt_ 's code...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/line-length-report/m-p/3942961#M311908
Hope this helps,
Henrique
Message 13 of 17
Thanks. This actually helps a lot, and is almost exactly what I want. I'll mark it down as a solution as I can work with it.
Is there a way of having the results displayed in a table? If not, then as MText rather than in the command bar?
Message 14 of 17
hmsilva
You're welcome, jcolesRA725
I have a deadline to meet, so at the moment, and I don't have much free time, but this @phanaem 's code should help
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/length-and-area-of-selected-objects/m-p/6576916#M344986
Hope this helps,
Henrique
Message 15 of 17
Hope this helps,
Henrique
Thank you very much. That is near enough exactly what I want. I'll be able to edit the lisp so it only gives me length.
You've saved me a long time learning how to do this from scratch.
Thanks again
Message 16 of 17
Slawomir_
I know that you have already found answer to your question, but perhaps this Meteor spec LT autocad app will shed new light on.
Message 17 of 17
reinaldo_togores
I believe this book I have written may help you in learning AutoLISP and Visual LISP:
http://lispexpert.blogspot.com/2018/07/release-2019-edition.html
Hope you find the information there useful.
