- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need the following commands in a lisp format
DRAW>POINTS>MULTIPLE POINTS
Regards
Philip
Regards
Philip
Try this.....
(defun c:MLP (/ pnt) (while (setq pnt (getpoint "\nSpecify a point: ")) (command "point" pnt)
) (princ) )
Also check this.....
https://www.cadlinecommunity.co.uk/hc/en-us/articles/201965421-AutoCAD-2013-The-MULTIPLE-Command
Thanks for the lisp, but when i use it i am getting the command line like (see image acad 001)
I am able to insert one point even I paste values at command point
if I do manual command (DRAW>POINT>MULTIPLE POINT) getting the command line like (see image acd002)
I am able to insert multiple points by paste (at once) the coordinates values
Hi
It's a string message only in command line......
If you continue with pick a piont on drawing it will place points on the picked position, until you press enter or escape.......
If you want the message in the command line like image ...002.png then change the line.....
With
(while (setq pnt (getpoint "\nPOINT Specify a point: "))
Another thing this code is only to place Multiple points as you asked. .....
Not for "Multiple" command, so it's behaviour is different........
If you want to use "Multiple" command....try this...
(defun c:MLP (/ pnt) (command "multiple" "point" "") (princ) )
I am not in system so I am little confused ...... the command line might be.....
(command "multiple" "point" "") ; or
(command "multiple" "point") ; or
(command "multiple" point "") ; or
(command "multiple" point) ; or
Please check it I can tell you after 2hr......
What do you mean by "paste (at once) the coordinate values"? Are you bringing in point-coordinate list variables somehow? Text-type comma-delimited coordinate strings? Something else? More than one Point's worth at one time?
Since the ribbon-based Multiple Points thing requires ESCape to end it, and doesn't end with Enter/space as @dbhunia's suggestion will, you could get equivalent operation with something as simple as this:
(defun C:PM () (while T (command "_.POINT" pause)))
It doesn't show the word POINT before the "Specify a point:" prompt as in your second image, but is that necessary? And when you hit ESC, it tells you it's cancelled in the form of an error message rather than just *Cancel*, but that could be adjusted with additional code, and it's operationally no different. Since I'm not sure what you mean by "paste (at once) the coordinate values," I couldn't say whether that command definition allows you to do that.
If you have a csv file then there is lots of import points lisp out there, have a look at Lee-Mac.com as a start.
Thanks kent1Cooper
It worked..
Thanks again
