Draw line between two list of points
jsaayman
Message 1 of 8
jsaayman
Hi
Is it possible to create a lisp program that will match the two points from a list off points that have the same x and y coordinate and different z coordinates. I want to be able to select all the points at the top and all the points at the bottom and then the program must match the points and draw a line between them.
Replies (7)
Message 2 of 8
marko_ribar
See if this can help you, I don't have time to test...
(defun c:zlines ( / ss i pl pl1 pl2 )
  (while
    (not (setq ss (ssget '((0 . "POINT")))))
    (prompt "\nEmpty sel.set... Reselect all points from both bottom and top positions that overlap in top view...")
  (repeat (setq i (sslength ss))
    (setq pl (cons (cdr (assoc 10 (entget (ssname (setq i (1- i)))))) pl))
  (while (vl-some '(lambda ( x ) (vl-member-if '(lambda ( y ) (if (equal (mapcar '+ '(0 0) x) (mapcar '+ '(0 0) y) 1e-6) (if (< (caddr x) (caddr y)) (setq pl1 (cons x pl1) pl2 (cons y pl2)) (setq pl1 (cons y pl1) pl2 (cons x pl2))))) (vl-remove x pl))) pl)
    (foreach x pl1
      (if (vl-position x pl)
        (setq pl (vl-remove x pl))
  (mapcar '(lambda ( a b ) (entmake '(0 . "LINE") (cons 10 a) (cons 11 b))) pl1 pl2)
  (princ)
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 3 of 8
Kent1Cooper
@jsaayman wrote:
.... I want to be able to select all the points at the top and all the points at the bottom and then the program must match the points and draw a line between them.
If you're talking about Point entities, here's another way [lightly tested]:
(defun C:LJPVA (/ ptss n ptlist ptA ptB); = Lines Joining Points Vertically Aligned
  (if (setq ptss (ssget '((0 . "POINT"))))
    (progn ; then
      (repeat (setq n (sslength ptss)); make into list of point lists
        (setq ptlist (cons (cdr (assoc 10 (entget (ssname ptss (setq n (1- n)))))) ptlist))
      ); repeat
      (repeat (1- (length ptlist))
        (setq ptA (car ptlist) ptlist (cdr ptlist))
        (foreach ptB ptlist
          (if (equal (list (car ptA) (cadr ptA)) (list (car ptB) (cadr ptB)) 1e-4)
            (command "_.line" "_none" ptA "_none" ptB "")
          ); if
        ); foreach
      ); repeat
    ); progn
  ); if
  (princ)
); defun
It works from one  selection of Point entities resulting in one  list of point locations, not two.  If you have some reason to want to select two separate sets of Points at top and bottom, I assume that can be accommodated, but it's not necessary.
Kent Cooper, AIA
Message 4 of 8
jsaayman
@Kent1Cooper Thanks for the reply. I’ll try the code and get back to you.
Message 5 of 8
marko_ribar
You could have checked my code too, and fix those errors...
  (while
    (setq pl (cons (cdr (assoc 10 (entget (ssname ss (setq i (1- i)))))) pl))
    (foreach x pl1
  (mapcar '(lambda ( a b ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b)))) pl1 pl2)
  (princ)
Message 6 of 8
jsaayman
@marko_ribar sorry I will check yours too. Thank you for the reply.
Message 7 of 8
daniel.valenciaQH2JE
i have a similar problem, i am trying to draw lines between two consecutive point (it can be consecutive in x or y), but i dont want to have one line over another, do you know how modify your routine for this?
Thank you
Message 8 of 8
jsaayman
Hi. No sorry I don't know how to modify the script to do this. But there
are a lot of intelligent people on the forum that will be able to help you.
