Arc Leader Line lisp not functioning as expected
jstogdill
jstogdill
We have a .lsp that was written several years ago and is now not working as it use to. This routine draws a pline from a specific point with a arc or loop on the end instead of an arrow. For some reason when you place "pt3" on the drawing "pt4" places automatically drawing a line instead of canceling the command. Here is the routine; (defun rtd (a) (/ (* a 180.00) pi) ) (defun c:aldr (/ multi lth dir pt1 pt2 pt3 pt4 ) (setq multi(getvar "dimscale")) (setq lth (* 0.0625 multi)) ;(command "osnap" "nea") (setq pt1 (getpoint "\nLeader start: ")) ;(command "osnap" "off") (setq pt2 (getpoint pt1 "\nNext point: ")) (setq dir (+ 90.0 (rtd (angle pt1 pt2)))) (setq pt3 (polar pt1 (angle pt1 pt2) lth)) (setq pt4 (polar pt1 (angle pt2 pt1) lth)) (command ".pline" pt3 "w" 0 0 "a" "d" dir pt4 "l" pt2) )
ВeekeeCZ
This works good to me.
Not sure whether you want the PLINE keep running or finish. Then remove or keep the last "".
(defun rtd (a)
  (command ".pline" "_non" pt3 "w" 0 0 "a" "d" dir "_non" pt4 "l" "_non" pt2 "")
  (princ))
jstogdill
Thank you for responding.....  This still isn't working correctly on my end.  It still sends a line off to nowhere when placing pt3....
If I remove the quotes "" at the end I only get a single line with the loop.
ВeekeeCZ
Do you have set UNITS to degrees?
jstogdill
The culprit turned out to be the command line for the ribbon button.  All is good now and thanks for the assistance..
