Hi friends ,
any body have a lisp programme for creating a line profile and chainage. I have attached a sample drawing. The blocks on the line have elevation and lines are drawn from the datum .If i mannually draw it will take too much time. if anybody have please send me thanks
Solved by pbejse. Go to Solution.
@Anonymous wrote:
I need a lisp program for creating road profile by using the existing contour or spot levels. with chainage .
Jeez, That explains a lot 😄
I take it you are not using Civil3D otherwise you wouldn't be asking for this,describe the problem, then post an example of before and after that way we wouldn't be guessing here., let's see how complex the end result before we commit to this task kalusalingam33
pBe
The long section and geometry details are available in "Civil Site Design" as well as multiple row data eg Left & Right Building lines.
Please find the lisp to quickly create longitudinal profile.
Please be reminded; you have to set all your contour in same layer. run the code "qp" and select the polyline you want to make profile from .
Enjoy your day.💪
