Hi friends ,
any body have a lisp programme for creating a line profile and chainage. I have attached a sample drawing. The blocks on the line have elevation and lines are drawn from the datum .If i mannually draw it will take too much time. if anybody have please send me thanks
Solved by pbejse. Go to Solution.
lokks like a tough one but doable. too bad dont know really much about chainage and profiles.
I notice there are two blocks use as reference in creating your profile,
Cross_circle_18 and
Cross_2 (inerpolated points?)
, are you using the same name block for every profile?
I believe profiiles are created with Y scale different for X scale, will it always be the same factor? (10)
What do you have so far? have you searched the forum the forum yet?
Only consider one block CROSS-2, this is for every profile.
scale is always same for all profiles ie x=1 and y=10. searched in the forum but didnt get
Ttry this for now:
(defun c:Cprof (/ pts pt_lst ins_pt a b c chn_lst) ;;; pBe 2011 ;; (vl-load-com) (if (setq pts (ssget '((2 . "CROSS-2,CROSS_CIRCLE-18") (8 . "CROSSING POINT,MPGN__POINTS_P3")))) (progn (mapcar '(lambda (p) (setq pt_lst (cons (cdr (assoc 10 (entget p))) pt_lst))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex pts)))) (setq pt_lst (vl-sort pt_lst (function (lambda (p1 p2) (< (car p1) (car p2)))))) (setq ins_pt (car pt_lst) ins_pt (list (car ins_pt) (setq c (+ (cadr ins_pt) 500.00)))) (while (and (>= (length pt_lst) 2) (setq a (car pt_lst))) (setq b (cdr pt_lst)) (setq ins_pt (append (list (nth 0 (car b)) (setq c (+ (* (- (last (car b)) (last a)) 10) c))) ins_pt) pt_lst b)) (setq chn_lst (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ins_pt))))) (vlax-safearray-fill chn_lst ins_pt) (vla-AddLightWeightPolyline (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) chn_lst))) (princ))
Thiis will draw the polyline for you and contrary to what you posted., i still process the block, crossing_circle_18 otherwise it would be incomplete.
Tried on the the attached file. it seems to do what you want
Dear pbejse ,
Thanks for the reply. I tried the lisp polyline is coming for cross-2 and cross circle blocks, it is good. Is there any way to make the chainage and vertical lines?. Also is it better or possible to go for visual basic. any way thanks for reply.
@kishku wrote:...... Is there any way to make the chainage and vertical lines?......
Somehow I knew you'll going to say that .
...... Also is it better or possible to go for visual basic.
I wouldnt say its better, possible yes.but IMO, with the recent migration from VBA to .NET on newAutocad versions
I think i would stick with Vanila lisp, plus i'm a beginner when it comes to VBA. sorry cant help you with that.
I will try to wirte a code for the "chainage" thingy, but you need to explain to me what those numbers are just to be on the clear.
135 M
146.70 <-- elevation?
0+000.000<--
0+100.002<-- distance?
are the text styles and text height constant?
BTW: judging bythe way the chainage is drawn i'm guessing you already have a routine for that. could you post it here and we can incorporate it with the previous code. (or you drawn this lines and text one by one?) it looks as if its done progmatically
Also if possible, post the interpolation code as well.
135 M
0+000.000<--
135 M datum
146.70 <-- elevation? yes elevation
0+000.000<-- starting chainage distance
are the text styles and text height constant? yes text styles and height constant
the sample done by some other person but he not revealing how he done. and also which lisp or vba used.
So you're telling me your company has a routine for that task and not sharing it?
Anyhoo.. i'll post the code later today.
keep you posted
try this
(defun c:Cprof (/ Text Line str_draw pts pt_lst z_val_str ins_pt a b c fdst chn_lst) ;;; pbe 22Mar2011 ;;; ;;; ;;; (vl-load-com) (defun Text (pt str) (entmakex (list (cons 0 "TEXT") (cons 10 pt) '(8 . "Profile") '(40 . 3.0) '(50 . 1.57143) (cons 1 str)))) (defun Line (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))) (defun str_draw (sts pls / base_y ptx zero+) (setq base_y (- (car pls) 120.00) cntr -1) (foreach str_ sts (text (list (setq ptx (nth (setq cntr (+ 2 cntr)) pls)) (- base_y 20.00)) (car str_)) (text (list (nth cntr pls) (- base_y 50.00)) (if (<= (vl-string-position (ascii ".") (setq zero+ (cdr str_))) 3) (strcat "0+" zero+) (strcat (substr zero+ 1 1) "+" (substr zero+ 2)))) (Line (list ptx (nth (1- cntr) pls)) (list ptx base_y))) (Line (list (nth 1 pls) base_y) (list (nth 2 ins_pt) base_y)) (Line (list (nth 1 pls) (- base_y 20.00)) (list (nth 2 ins_pt) (- base_y 20.00))) (Line (list (nth 1 pls) (- base_y 50.00)) (list (nth 2 ins_pt) (- base_y 50.00))) (princ)) (if (setq pts (ssget '((2 . "CROSS-2,CROSS_CIRCLE-18") (8 . "CROSSING POINT,MPGN__POINTS_P3")))) (progn (mapcar '(lambda (p) (setq pt_lst (cons (cdr (assoc 10 (entget p))) pt_lst))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex pts)))) (setq pt_lst (vl-sort pt_lst (function (lambda (p1 p2) (< (car p1) (car p2)))))) (setq ins_pt (car pt_lst) ins_pt (list (car ins_pt) (setq c (+ (cadr ins_pt) 500.00))) fdst (nth 0 (car pt_lst))) (while (and (>= (length pt_lst) 2) (setq a (car pt_lst))) (setq b (cdr pt_lst)) (setq z_val_str (cons (cons (rtos (last a) 2 3) (if (not z_val_str) "000.000" (rtos (- (car a) fdst) 2 3))) z_val_str)) (setq ins_pt (append (list (nth 0 (car b)) (setq c (+ (* (- (last (car b)) (last a)) 10) c))) ins_pt) pt_lst b)) (setq z_val_str (cons (cons (rtos (last (car pt_lst)) 2 3) (rtos (- (car (car pt_lst)) fdst) 2 3)) z_val_str)) (str_draw (reverse z_val_str) (reverse ins_pt)) (setq chn_lst (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ins_pt))))) (vlax-safearray-fill chn_lst ins_pt) (vla-AddLightWeightPolyline (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) chn_lst))) (princ))
Reminder: (disclaimer);;Not really
This will work ONLY under this conditions
Blocks with the names
"CROSS-2" and "CROSS_CIRCLE-18"
Under layers
"CROSSING POINT" "MPGN__POINTS_P3"
Same units
Same textstyle
same height
As your sample drawing
AND i leave the Datum value to you. I have no idea where to reference that
Hope thi helps
THANKS PBAJSE its working well, now my work reduced i can do i week work in one minute. THANKS A LOT. Only some negligible points like datum. it is not a problem i can correct it. THANKS A LOT DEAR
You are welcome.
Thats what we're here for,
IMO the purpose of this forum is to help, teach, learn and SHARE
Have fun profiling
Gud day to all can you help me solve this problem.
Do you have a lisp that will indicate all the crossings in proposed center line on the profile.( mud road, over head line,Steel Fence, valley crossing)
with the same location of stationing on the propose centerline to profile.
attach drawing for sample...
Pleaseeeeeeeeeeeee...
Hi, this script is great! I am wondering how to modify it in order to draw two sets of data, for example a pipe running under the profile. Can you help me?
@Anonymous wrote:
May I know the commend for this lisp (LISP FOR LINE PROFILE AND CHAINAGE)
Wow, this thread is 5 years old and there's a few requests along the way 😄
Perhaps we can write a new one for your kalusalingam33., what is it you require?
I need a lisp program for creating road profile by using the existing contour or spot levels. with chainage .
