LISP for Excelsheet to TagValue in DWG.
Hello everyone, let me introduce you to the Challenge.
Four drawings, with four complety diffrent blocks, 16 Blocks total.
I am trying to automate the values inside each diffrent block correspondig to:
  • DWG NAME
  • BLOCK NAME
  • TAG NAME
  • VALUE
E.g. :
Great start in the Topic is Update Titleblock Attributes | Lee Mac Programming .
Problem:
 Tag names change between blocks. Tag1 can be  "Diameter" in the first block and Tag1 can be "Hight" in a diffrent Block.
These guys just made one but w/o the drawing defenition. Also with limited numbers of tags to value.
BUT.. they can count the Tags instead of defining them by name.
Sorry if this is a bit whacky explained, cant post a DWG,CVS or XLSX as always. I hope you got the point.
Heres another example with ,hopefully, a clear indication whats the problem.
Thanks alot for the work and thought anyone is gonna put into this - I am trying to clearify the task as good as i can, so please ask.
Greetings
pbejse
What you're asking is not that difficult.
Show dwg-1 and dwg-2 with 4 blocks each on the table and their tags for us to get a better picture
JTBWorld
Are you only looking for someone to do the work for free for you or do you try to learn programming?
If you look for an existing solution we have JTB CAD Automation Tools
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
