Documents.Open fails, while ActiveDocument succeeds
oransen
oransen
I'm at a loss as to why this is, here is the code, I've missed something important I imagine:
            // Open AutoCAD and get it as a variable in C#...
            AcadApplication AcadApp;
            AcadApp = new AcadApplication();
            // Make sure the AutoCAD windows are visible
            // (But note that making it invisible probably speeds up processing.)
            AcadApp.Application.Visible = true;
            AcadDocument AcadDoc;
#if false
            // Get the active document, which in this case is the default empty document which
            // This uses the default document AutoCAD starts with, and works
            AcadDoc = AcadApp.ActiveDocument;
#else
            // This opens a document, but any attempt to use it fails
            AcadDoc = AcadApp.Documents.Open(@"D:\Temp\CSHARP.DWG");
#endif
            AcadDoc.Layers.Add("TestLayer");
            // Model space is actually where most of the entities (LINE,CIRCLE,POINT etc) in an AutoCAD DWG file live.
            var ModelSpace = AcadDoc.ModelSpace;
See the stuff around "#if false"
The error message is (translated from Italian) the "called has rejected the caller's function call"
hak_vz
Post your request in .NET forum
Miljenko Hatlak
oransen
Yes, it is a bit confusing, there is an explicit VBA forum but no C# forum.
