Hello, is it possible to write a LISP program for "connect to data"?
Here is the link to the AutoCAD helpdesk tutorial, so you can better understand what I mean.
https://help.autodesk.com/view/MAP/2024/ENU/?guid=GUID-A6304264-F4A9-4391-AC0D-4ECB568E9639
I need to repeatedly connect to WMS and use a hectometric grid and aerial images for the drawing. I would like to try to simplify it somehow, as I connect to the data maybe 10 times within 5 minutes.
I tried record a macro, but it didn't work. Also, when I click on "connect to data," it doesn't display any command in the command line that I could use when writing the LISP code.
