LISP for cennect to data
1 REPLY 1
wulfgarcze
194 Views, 1 Reply
Hello, is it possible to write a LISP program for "connect to data"?
Here is the link to the AutoCAD helpdesk tutorial, so you can better understand what I mean.
https://help.autodesk.com/view/MAP/2024/ENU/?guid=GUID-A6304264-F4A9-4391-AC0D-4ECB568E9639
I need to repeatedly connect to WMS and use a hectometric grid and aerial images for the drawing. I would like to try to simplify it somehow, as I connect to the data maybe 10 times within 5 minutes.
I tried record a macro, but it didn't work. Also, when I click on "connect to data," it doesn't display any command in the command line that I could use when writing the LISP code.
1 REPLY 1
LDShaw
in reply to: wulfgarcze
Not sure it will help other than bump you but
Some lite reading
https://www.theswamp.org/index.php?topic=58733.msg617099#msg617099
Forma Design Contest
AutoCAD Beta
