Join multiple Dtext contents
Message 1 of 26
Hi all.
Is there a lisp to join two "dtext" text contents in one single text line? Maybe all the text on the same Text Alignment Y value?
Replies (25)
Message 21 of 26
ronjonp
Another one for fun 🙂
(defun c:foo (/ a i s)
  (cond	((setq s (ssget ":L" '((0 . "text"))))
	 (setq s (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))))
	 (setq
	   s (mapcar '(lambda (x) (list x (cdr (assoc 1 (entget x))) (cdr (assoc 10 (entget x))))) s)
	 (setq s (vl-sort s '(lambda (r j) (< (caaddr r) (caaddr j)))))
	 (while	(setq i (car s))
	   (setq a (vl-remove-if-not '(lambda (x) (equal (cadr (last x)) (cadr (last i)) 1e-2)) s))
	   (entmod (append (entget (car i)) (list (cons 1 (apply 'strcat (mapcar 'cadr a))))))
	   (and (> (length a) 1) (mapcar 'entdel (cdr (mapcar 'car a))))
	   (mapcar '(lambda (x) (setq s (vl-remove x s))) a)
  (princ)
)(vl-load-com)
Message 22 of 26
Thank you.
Message 23 of 26
ronjonp
You're welcome 🙂
Message 24 of 26
duynhat151092
Hello
Can you help me with this lisp vertically.
Thank.
Message 25 of 26
duynhat151092
Hello
Thank.
Message 26 of 26
patrickBG24Z
Just what I was looking for! Thanks
