Dimension Settings
Dimension Settings
Message 1 of 8
Dimension Settings
 I've developed a LISP routine that auto dimensions the width of right of way for pipeline projects. However, I'm having some trouble getting dimensions to display as preferred. The text will generate at the angle of the sheet window (cyan line) but the landing lines are staying horizontal with the world UCS. Any idea what setting controls the landing line? I've used Lee Mac's dump function to understand what properties are associated. Right now, "Rotation" is set to 0.0 & "Text Rotation" is at the angle of my sheet window.
Any suggestions?
Replies (7)
Message 2 of 8
ВeekeeCZ
Try Dimtih?
(setpropertyvalue (car (entsel)) "Dimtih" 0) ;0/1
Message 3 of 8
That didn't do it. Were you attempting to change the text position?
Message 4 of 8
ВeekeeCZ
Sorry, I was wrong. Don't think you gonna find anything.
Obvious question, why don't you rotate UCS during the routine run? Sure, it would a bit slower, but...
Message 5 of 8
I've done that and the landing line still displays as if I hadn't.
Message 6 of 8
CodeDing
@Anonymous,
Maybe remove your leader all together, this should remove the leader portion that is irking you.
Just my attempt at it.. Hope this helps.
Best,
~DD
Message 7 of 8
I'm not wanting to get rid of the landing line. I want it to be aligned with the text.
Message 8 of 8
CodeDing
@Anonymous,
Looks like it can be done with AcitveX. Here are 3 good resources which provide insight to the code. I've not used it so I can't provide a practical example.
Source 1 - Autodesk knowledge network. Inputs / outputs
Source 2 - AutoCAD forum answered question. Shows VBA implementation.
Source 3 - The swamp. Lee mac provides a code in one of the first comments that shows it being used with LISP. (vla-setdoglegdirection...)
Hope these get you on the right path!
Best,
~DD
