Is there a GATTE equivalent for LT2025
h_s_walker
Mentor Mentor
Message 1 of 53
h_s_walker
Ok so we will do drawings, sometimes with many pages.
In our title block with have an attribute for the name of the client.
Originally it is blank, but quite often the project leader does not give us the client name until late in the game when we've done many layout tabs.
Now you can understand going into each layout just to put in the client name is a PITA.
So is there a gatte equivalent I can use for LT2025
Howard Walker
Left Handed and Proud
Accepted solutions (3)
Replies (52)
Message 41 of 53
h_s_walker
@komondormrex only a very tiny little thing. I know that sometimes our cad guys (myself included) will not always have the capslock on.
Is there any way to make it so that when the attribute tag is typed in it automatically goes all caps?
Howard Walker
Message 42 of 53
cadffm
@h_s_walker  schrieb:
 The PLC you can see in the image below
I can see the image,
but I can't check blocks, blockreferences and Attributes.
PLEASE share this title part (orignial drawing, delete all other stuff).
I think that's fair, lots of helpers, lots of work, then we should at least be able to resolve the problem.
Sebastian
Message 43 of 53
h_s_walker
@cadffm @komondormrex has almost got it perfectly sorted, I just asked if he could make it so that when typing in the attribute to change it automatically changes to all caps
Howard Walker
Message 44 of 53
cadffm
And I ask about a sample file where applyclient doesn't work ( the .dwg you screenshot)
Sebastian
Message 45 of 53
komondormrex
@h_s_walker
check updated code i posted earlier. it will strcase tag input not when typing but when typing is done. hth.
Message 46 of 53
h_s_walker
@cadffm Here is a sanitised drawing with all the relevant information removed which will not change the client name
Howard Walker
Message 47 of 53
h_s_walker
@komondormrex Perfect. Thanks
Howard Walker
Message 48 of 53
komondormrex
your welcome!
Message 49 of 53
cadffm
and you tested this file before upload?
cadffm: If test1. faild, do the same as before
              Delete all problematic entries, save the file under a different name.
              Close the file, open this file, load applyclient and run it.
              Is the problem still there? Then share this DWG.
If so, sorry. The code works very well in LT2025.1.1, what I installed specially for you and your files.
"2 attribute(s) update."
Attachment is 100% the same code as above (13349036#13346232)
Sebastian
Message 50 of 53
h_s_walker
@cadffm I don't know what's changed, but that's working now.
I shall use both yours and komondormrex lisps
Howard Walker
Message 51 of 53
cadffm
Then everything is fine,
I assume that the problems were not due to the program itself.
I just want to make it clear that the Lisp is by @Moshe-A , not really mine.
h_s_walker,  If you like, there are additional messages integrated here, so you are made aware of locked layers or other problems <click>
Command: APPLYCLIENT
Client name: fff
1 update failed (Block: ATTRIBA1a | Att-Layer: 0_UK | Tab: A1_5522-2)
2 attributes updated, 1 failed
Command:
Sebastian
Message 52 of 53
pendean
Community Legend
Community Legend
Message 53 of 53
dbroad
Thanks.  I still think that fields are much better than programming for such tasks.
Architect, Registered NC, VA, SC, & GA.
