Is there a GATTE equivalent for LT2025
h_s_walker
Mentor Mentor
Message 1 of 53
h_s_walker
Ok so we will do drawings, sometimes with many pages.
In our title block with have an attribute for the name of the client.
Originally it is blank, but quite often the project leader does not give us the client name until late in the game when we've done many layout tabs.
Now you can understand going into each layout just to put in the client name is a PITA.
So is there a gatte equivalent I can use for LT2025
Howard Walker
Left Handed and Proud
Accepted solutions (3)
Replies (52)
Message 21 of 53
h_s_walker
@dbroad LT2025 does support lisp, although not everything works in LT, that is why I'm posting here.
@cadffm I can't get any of them to work. When I try it doesn't do anything
Howard Walker
Message 22 of 53
Moshe-A
@h_s_walker ,
Check this fix, specially how variable BNAME is set, '*' character must be added at end of string to address any title block name starting with "attribaxxxx". another 'issue' ... you did not mention the title block is dynamic so i fix this also.
works fine on my vanilla R2024 😀
enjoy
Moshe
; apply client
(defun c:applyClient (/ BNAME TAG client ss ctr ename subent sube)
 (setq BNAME "attriba*") ; const
 (setq TAG   "client")   ; const
 (if (and
       (/= (setq client (getstring t "\nClient name: ")) "")
       (setq ss (ssget "_x" (list '(0 . "insert") (cons '2 (strcat BNAME ",`*U*")) '(66 . 1))))
  (progn
   (setq ctr 0)
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq subent (entnext ename) sube (entget subent))
    (while (/= (cdr (assoc '0 sube)) "SEQEND")
     (if (eq (strcase (cdr (assoc '2 sube))) (strcase TAG))
      (progn
       (entmod (subst (cons '1 client) (assoc '1 sube) sube))
       (setq ctr (1+ ctr))
      ); progn
     ); if
     (setq subent (entnext subent) sube (entget subent))
    ); while
   ); foreach
   (cond
    ((= ctr 0)
     (prompt "\nNo attributes found to update.")
    ); case
    ( t
     (prompt (strcat "\n" (itoa ctr) " attribute(s) update."))
    ); case
   ); cond
  ); progn
 ); if
 (princ)
); c:applyClient
Message 23 of 53
cadffm
may I..
(cons '1 client) - quote numbers works, but is not needed, numbers evaluate to themselve
(cons 1 client)
(entmod (subst (cons '1 client) (assoc '1 sube) sube)) - can work and can also fail, if someone edited the multiline attributvalue by hand, this code will not change the value
(entmod (subst (cons '1 client) (assoc '1 (reverse sube)) sube))
and I added IF-effectivename, so that anonym blocks variants of bname blocks be processed only.
 (if (and
  (progn
   (setq ctr 0)
    (if (wcmatch (strcase (vla-get-EffectiveName (vlax-ename->vla-object ename)))(strcase BNAME))
      (progn
       (setq ctr (1+ ctr))
      ); progn
     ); if
    ); while
    ); if
   ); foreach
   (cond
    ((= ctr 0)
    ); case
    ( t
    ); case
   ); cond
  ); progn
 ); if
 (princ)
@h_s_walker
Does it work now?
Have your tried my basic solutions too and does they work as expected?
Come on! to keep one's fingers crossed
All the codes(some, with edits) and workaround working in your given .dwg sample
Sebastian
Message 24 of 53
cadffm
Please test with short values,
Like
Test Value
For looong  values, it's possible you need a more complicated code.
Sebastian
Message 25 of 53
Sea-Haven
This is what I did for a similar post it makes a dcl on the fly with tag names so you enter correct values leave any to not change blank.
; update a block atts in multiple layouts
; By AlanH March 2025
(defun c:upatts ( / ans atts bent bname lay lst lst2 obj ss x)
(setq obj (vlax-ename->vla-object (car (entsel "\nPick block object "))))
(setq bname (vlax-get obj 'name))
(setq atts (vlax-invoke obj 'Getattributes))
(setq lst '())
(foreach att atts
  (setq lst (cons (vlax-get att 'Tagstring) lst))
(setq lst2 '())
(foreach val lst
  (setq lst2 (cons "" lst2))
  (setq lst2 (cons 20 lst2))
  (setq lst2 (cons 21 lst2))
  (setq lst2 (cons val lst2))
(setq lst2 (cons "Please choose " lst2))
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm lst2))
(foreach lay (layoutlist)
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 bname)(cons 410 lay))))
(setq x 0)
(setq bent (vlax-ename->vla-object (ssname ss 0)))
(setq atts (vlax-invoke bent 'Getattributes))
(repeat (length atts)
  (if (= (nth x ans) "")
  (princ)
  (vlax-put (nth x atts) 'textstring (nth x ans))
  (setq x (1+ x))
(princ)
Message 26 of 53
Moshe-A
@cadffm
(cons 1 client)
i know that but it is many years of habit and i can't help it 😀 think i took it from some one here long time ago, at least i consoled it does not harm the code.
well, generally i do not use Multiple attribute mode and i was not aware of that - thank you for that info.
As i mentioned i have no AutoCAD LT, thought LT does not support ActiveX. can we now assume AutoLISP for LT is the same as full  AutoLISP?
Message 27 of 53
cadffm
I missing my last post, here is a shorter version:
Lisp in LT is limitted. 99% explaind with few words / two links
-No access to other programs, no vlax get or create
-Can't create objects what are not part of LT, like meshs, what is logical
- Can not create Xrecords and dictionaries
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-037BF4D4-755E-4A5C-8136-80E85CCEDF3E
https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-D47983BA-1E5D-417D-85B8-6F3DE5F506BA
Sebastian
Message 28 of 53
komondormrex
@h_s_walker
check the following. hope it will work in lt.
;	'other_gatte' custom command modifies value of selected by tag attribute in picked block to implement the same modifications
;	in the same blocks throughout all layouts of the drawing.
;	komondormrex, mar 2025
(defun c:other_gatte (/ att_block insert tag_value_att_list tag_list value_list tag new_value tags_changed attribute_found)
	(while (not att_block)
		(setq insert (car (entsel "\nPick block with attributes: ")))
		(if (equal '(66 . 1) (assoc 66 (entget insert))) (setq att_block t))
  	(setq tag_value_att_list (mapcar '(lambda (attribute) (list (vla-get-tagstring attribute) (vla-get-textstring attribute) attribute))
  				            (vlax-invoke (vlax-ename->vla-object insert) 'getattributes)
  		  tag_list (mapcar 'car tag_value_att_list)
  		  value_list (mapcar 'cadr tag_value_att_list)
  	(while (and (setq tag (getstring (strcat "Select attribute, {Enter} to end ["
  						    				  (apply 'strcat (cdr (apply 'append (mapcar 'list (mapcar '(lambda (x) "/") tag_list) tag_list))))
  		        (/= "" tag)
  	  	   (if (member (setq tag (strcase tag)) tag_list)
  		 	    (if (/= "" (setq new_value (getstring t
  		 				         					(strcat "\nEnter new value for \""
  		 				         					  	   	(vla-get-tagstring (last (assoc tag tag_value_att_list)))
  		 				         					 	   	(vla-get-textstring (last (assoc tag tag_value_att_list)))
  		 			(progn
  		 	    	 	   (vla-put-textstring (last (assoc tag tag_value_att_list)) new_value)
  		 			   (if (not (assoc tag tags_changed)) (setq tags_changed (append tags_changed (list (cons tag new_value)))))
  	(vlax-map-collection (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
  	  '(lambda (layout) (if (/= "Model" (vla-get-name layout))
  				(vlax-map-collection (vla-get-block layout)
  				  '(lambda (object) (if (and (not (equal (vlax-ename->vla-object insert) object))
  							     			 (= "AcDbBlockReference" (vla-get-objectname object))
  							     			 (= (vla-get-effectivename (vlax-ename->vla-object insert)) (vla-get-effectivename object))
  						        		(mapcar '(lambda (tag) (if (vl-some '(lambda (attribute) (= tag (vla-get-tagstring (setq attribute_found attribute))))
  												     			   			 (vlax-invoke object 'getattributes)
  											   					  (vla-put-textstring attribute_found (cdr (assoc tag tags_changed)))
  									 			 (mapcar 'car tags_changed)
  	(princ)
updated
Message 29 of 53
Moshe-A
@cadffm
Sorry maybe i am missing something here?
if it has no (vlax-) functions how did you recommend doing that?
Message 30 of 53
cadffm
>>"if it has no (vlax-) functions"
Yes, you missunderstood my on mobile fast written sentence and didn't read my links.
I wrote "no access to other programs"
and my sample -  was function
vlax get or create
known as "vlax-get-or-create"
but I mean all api methods to enter another program by api.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/is-there-a-gatte-equivalent-for-lt20...
Sebastian
Message 31 of 53
Moshe-A
ok thanks you now it's clear
Message 32 of 53
Sea-Haven
@h_s_walker its your turn now need your comment about what did work. Most of us have no access to LT24+.
As mentioned VLAX- may not work but you can change those commands back to a (VLA-get-attributes obj) as an example
Message 33 of 53
h_s_walker
@cadffm your tweak to @Moshe-A is almost exactly what I need. One problem (which is probably easy to solve for you lisp gurus).
Sometimes we will be given a client name and we will use that and then later in the game the client will change.
Is there a tweak you can do to the code you posted here Re: Is there a GATTE equivalent for LT2025 - Page 3 - Autodesk Community  so it can change it even if there is already a client name there?
Howard Walker
Message 34 of 53
cadffm
Please excuse Howard, but I'm getting desperate here and now.
Take the code, posted as last from me
If anything doesn't work, I'm sure the others will help you.
Sebastian
Message 35 of 53
cadffm
or start to share a sample what fails with this code and new attribute value.
Sebastian
Message 36 of 53
h_s_walker
@cadffm
I was loading up one of our drawings, which I obviously cannot share, and it refuses to change the client name.
HOWEVER when I loaded up the drawing I created with all the information removed it will quite happily change the client name.
Howard Walker
Message 37 of 53
cadffm
>>"I was loading up one of our drawings, which I obviously cannot share, and it refuses to change the client name."
1. Try it again with this file, re-open this dwg,
    unloack layers, load the latest applyclient code, run applyclient
2. If test1. faild, do the same as before
    Delete all problematic entries, save the file under a different name.
    Close the file, open this file, load applyclient and run it.
    Is the problem still there? Then share this DWG.
Sebastian
Message 38 of 53
h_s_walker
@cadffm I've just rebooted my machine. Loaded up a totally different drawing. The PLC you can see in the image below is part of the client name and as you can see from the text box in the image below it should say blah. Don't worry about the black scribble that's only part of the company name I work for.
Howard Walker
Message 39 of 53
h_s_walker
@komondormrex That's just about perfect. I'm sure I can easily show the other cad guys how to use it, and it will also help with changing other attributes which stay constant over each page.
Howard Walker
Message 40 of 53
komondormrex
what is missing to be one?)
